Author Topic: Adjusting the chain  (Read 958 times)
Offline blackops
Adjusting the chain
« on: April 14, 2011, 21:55:24 »
Since I fitted my pyramid hugger the chain has been catching the front of the hugger its fitted as per the instructions I can only think that the chain may be to slack? I gather that any adjustments must be made on the sidestand and the tolerances are between 20-30 mm does any body have the correct procedure for tightening chains please.
Offline Fatbelly
Re: Adjusting the chain
« Reply #1 on: April 15, 2011, 00:55:57 »
20-30mm at the SLACKEST point, chains don't always stretch evenly.
Offline Squirrelciv
« Reply #2 on: April 15, 2011, 07:02:41 »
... and make sure to top of the chain is in tension. (bike in gear and rotate rear wheel)
Live long. Live well. Live happy.
Offline Sven
« Reply #3 on: April 15, 2011, 07:29:07 »
Others have had the same problem. Have a look here.
Think it just wears a little bit away & then its no problem. :shrug:
viewtopic.php?f=1&t=6779
Offline Stuart
« Reply #4 on: April 15, 2011, 20:22:05 »
I'd the exact same problem when I first fitted the Pyramid hugger.  Still happens to a (annoying!) degree!  I'm considering cutting the front back an inch or so to allow for chain play (my chain's at the correct tension) - if that'll work!!
Offline biker1
« Reply #5 on: April 16, 2011, 08:38:55 »
so how do you adjust the chain with the bike on the side stand ?
Offline Bandageman
« Reply #6 on: April 16, 2011, 09:44:27 »
I've always done mine on the centre stand or if the bike doesn't have a centre stand, up on  some wooden blocks
Offline longman
« Reply #7 on: April 16, 2011, 10:00:28 »
I followed the manual so I did mine on the side stand, loosened the axle nut, then adjust the chain with the adjusters on both side of the bike, tighten the the axle nut again - just in case I also checked that the wheels are in line with the 7 foot metal bar - job done.
Longman
Suzuki DL650 K5
Suzuki DR-Z400SM K7
Offline Bandageman
« Reply #8 on: April 16, 2011, 14:13:32 »
Quote from: "longman"
Nice one  :obscene-drinkingchug:
