I'm actually in the process of looking for some new kit, I need to have it before the winter cold sets in and it needs to keep me comfy for the full 1.5 hour commute I have (3 hours both ways.) My current textiles have survived a fall, have a hole in an awkward place (high up, inside of the right thigh, the seam came loose.) Considering that they were used practically every day for the past 15 months I'd say they were great. They cost me less than £200 and they have removable water & windproof inner and removable thermal inner (these are the Akito Desert textiles if anyone knows them.) The problem with them is that you need to zip in the wind & waterproof liner when you need it. This is a real hassle if the weather changes quickly. Also, because the wind & waterproof liner zips on the inside the textile suit gets wet through and takes a long time to dry. I'd prefer something that is wind & waterproof already with a zip in thermal liner if it gets cold. But again, for the price they were great.
These Halvarssons ones looks really good without being priced too extreme like some of the other brands. Thanks for the heads up
Now I need to find a place closer to me that sells them so I can go try them on.
If anyone has any other recommendations on good textile that will handle whatever the UK weather can throw at you with heavy use, please do post a mention of it.
EDIT:
http://www.hideout-leather.co.uk/ also sells them.
