Author Topic: back ache  (Read 1266 times)
Offline milano_jon
back ache
« on: June 14, 2010, 12:12:58 »
Does anyone else suffer with back ache on the weestrom? This is my first bike, so I might just be prone to it, or need to relax or whatever...
Any tips?
Orange 2010 DL-650GT-L0
Offline doublevodka
Re: back ache
« Reply #1 on: June 14, 2010, 13:15:29 »
How tall / heavy are you, what's your riding style / position etc etc, all the questions you are going to be asked ;)
Alcohol, the cause, and solution to many of lifes problems!
Offline milano_jon
Re: back ache
« Reply #2 on: June 14, 2010, 13:18:03 »
6ft 2in. 15stone 7lb
I sit up but try to stay flexible. I don't tend to move my arse though, but then I'm new to riding so take corners gingerly.
Offline Fatbelly
Re: back ache
« Reply #3 on: June 14, 2010, 13:53:51 »
Maybe you are more tense than you realise.Try to make sure your elbows are always slightly bent - that tends to make you relax all over a little bit more. Remember, the bike actually handles better with a relaxed rider. So, just take a deep breath occasionally and tell yourself to relax, it'll soon become second nature.
Offline cearnshaw
Re: back ache
« Reply #4 on: June 14, 2010, 13:56:01 »
when I started riding I got terrible backache but I don't get it at all now. Change your position, move around a bit on the bike and as you improve your body will be less tense
Honda xr125, Bandit 650, v-strom 650 ABS 2001 W650 Versys 1000
Offline doublevodka
Re: back ache
« Reply #5 on: June 14, 2010, 13:59:40 »
ah about same weight and build as me then, prob first this is get a taller seat, this will help posture, swap with a short arse 1000 rider first to see if helps, then there are loads of other options like bar risers etc which will change your posture, good luck with whatever you do
Offline Fenris
Re: back ache
« Reply #6 on: June 14, 2010, 16:08:53 »
Quote from: "cearnshaw"
Same here - it went fairly quickly. I did quite a lot of long days recently and it was fine. I'm guessing certain muscles just need to get used to it.
GPX750 > GS500 > Hornet 600 > DL1000
Offline Dodge
Re: back ache
« Reply #7 on: June 14, 2010, 17:29:55 »
Quote from: "milano_jon"
I agree with everyone on this, you need to relax and feel part of the bike instead of riding it.  When it comes to cornering you don't need to shift your weight too much at first, I tend to just lift the cheek of my arse as though I am slipping out a sneaky one when I corner, that really smooths it out for me.... try it and see how you feel mate.... but be patient and careful....
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to Skid in Sidways, thoroughly used up, totally worn out, and screaming "Here I am --- What a Ride!"
Re: back ache
« Reply #8 on: June 14, 2010, 18:08:27 »
The Seat was a nightmare for me - changed it
Raising and moving back of the Bars also helps  :thumb:
Offline Dracula
Re: back ache
« Reply #9 on: June 14, 2010, 20:08:52 »
I'm a reasonably new rider too, same height/weight. I still get a little back ache when I forget to relax, more aching with a pillion. Relax, relax, relax.
Oh and I swapped my seat for a 1000 one too, much better for both me and the missus as pillion.
"There are no ugly women..... Just not enough Vodka!"
Offline Dodge
Re: back ache
« Reply #10 on: June 15, 2010, 09:00:35 »
I have a new 1000 seat for sale if you are interested.......
Offline milano_jon
Re: back ache
« Reply #11 on: June 15, 2010, 14:42:48 »
pm'd
Offline chesterman
Re: back ache
« Reply #12 on: June 15, 2010, 20:45:28 »
I never had a problem on the 1000 but on the 650 the top of my back neck and shoulders ache badly after a few miles I've ridden allsorts  of bikes over the years and never had a problem,maybe I'm just getting old it's the only fly inthe oinment of an otherwise brilliant bike.
