Author Topic: Leaky front forks.  (Read 422 times)
Offline bobbymc
  • Bike: DL650 K9
Leaky front forks.
« on: April 12, 2025, 11:47:32 »
Just noticed a leak on my front forks, not surprising 16 years old but good.
I replaced the fork seals on my CB750 F2 before....so, are there any pitfall I should look out for, I know I need to get genuine replacement parts !....many thanks in advance.....bob
I have a 2009 DL650.
Online The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4.
Re: Leaky front forks.
« Reply #1 on: April 12, 2025, 12:38:04 »
Bobby, you have posted your question in the introduction part of the site. Maybe V-Strom discussion thread  will bring more answers. Good luck with the forks.  :thumb:
Offline nigel s
  • Bike: DL650A M2 , 06 CBR600RR
« Reply #2 on: April 13, 2025, 04:37:43 »
Do you have a seal mate bobbymc ?
https://www.ebay.co.uk/itm/205399970619?chn=ps&_ul=GB&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=205399970619&targetid=2404040183267&device=c&mktype=pla&googleloc=9044855&poi=&campaignid=21697363421&mkgroupid=171407487490&rlsatarget=pla-2404040183267&abcId=10027088&merchantid=119226922&gad_source=1&gbraid=0AAAAAD_Lr1fAZSiHmH3HbA8n_dd0_xTX-&gclid=Cj0KCQjwnui_BhDlARIsAEo9Guuuc-C4JY5CxgDjRV42_NWDJ9ymlnRPeG78TOTkLZ9ySFy68zgeFPgaAlYkEALw_wcB
If I have a leaky fork seal I try running one round before replacing the seal . Sometimes works..sometimes doesn't  :shrug:  If it has been leaking a while though , even if the sealmate works you may have to check and top up the oil due to loss, and might as well change the oil anyway in that case.
Depending on how many miles on the bike the fork bushes may be worn and now is the time to check and replace if needed.
Now is also the time to upgrade with emulators , if you feel the need.
https://www.v-strom.co.uk/smf/index.php?topic=31714.msg313834#msg313834
 I use a piece of pvc pipe to reseat the new seals. As you have done right way up forks before the 650s are bog std so nothing else to look out for.
Offline cooltshirt
  • Bike: DL650 L6
« Reply #3 on: April 13, 2025, 07:26:40 »
 :thumb: to a sealmate. Definitely worth a shot, seems to have worked for me.
« Reply #4 on: April 14, 2025, 08:22:01 »
If I recall, the fork seals from Suzuki where supplied as a single kit for one side, thus if both side needed to be done, two set of seals had to be ordered.
The fork seals being pricey at the time, I could have saved a few quid, by rather buying the Honda 51490-MCF-000 kit which as for the Suzuki kit, also comes for a single side.
In as far a guide on how to do the work, have a look at the attached.  Let me know how you get on with this project.
Online Joe Rocket
« Reply #5 on: April 15, 2025, 20:05:31 »
Cheap version of Seal Mate, cut a plastic Coke bottle to a similar shape approx. 10 x 2.5 cm. It's not rocket science or anything special it just allows you to clean gunge out that may be trapped between the seal and stanchion.
As said, give it a try first. If the seal has been slightly disturbed give it overnight to find it's original form.
Hope that's all it is.  :icon_wink:
