Author Topic: Topbox rubber  (Read 997 times)
Offline AeronW
  • Bike: 2016 v-strom 650
Topbox rubber
« on: April 06, 2025, 12:52:36 »
Took my top box off yesterday to give the bike a good clean and noticed one of the rubbers was missing, which would explain the rattling. Where could I purchase a replacement?
Re: Topbox rubber
« Reply #1 on: April 06, 2025, 14:10:33 »
A Google search for "Givi rear carrier rubber bungs" produced these, plus others.
https://www.ebay.co.uk/p/27021988607
If yours isn't a Givi plate, search for your make.
Offline AeronW
Re: Topbox rubber
« Reply #2 on: April 06, 2025, 14:52:15 »
The top box itself is Suzuki branded. Optional extra when new I expect.
 This is what the rubber looks like.
Re: Topbox rubber
« Reply #3 on: April 06, 2025, 19:46:43 »
All I can say is, search for them using Suzuki in the wording but I'm sure those or similar that the link shows will fit or can be made to fit. (& may well be cheaper than Suzuki OEM ones too)
Then, when you find some that you can use, either silicone them into place or superglue them. When the top box sits on them for a while they stick to the underneath & pull out when you lift the top box off & fall off never to be seen again.
Offline Upt North
  • Bike: DL650 L7
Offline DesertStrom
  • Bike: DL650 K9, Triumph Street Scrambler
Re: Topbox rubber
« Reply #5 on: April 08, 2025, 18:47:42 »
PM sent
