Author Topic: Lubrication for brake calipers  (Read 95 times)
« on: February 25, 2025, 21:03:47 »
What's a good grease for brake caliper slide pins?
Online Rixington43
  • Bike: DL1000GT K7
Re: Lubrication for brake calipers
« Reply #1 on: February 25, 2025, 21:28:22 »
Red rubber grease has always been my go to on brakes.
Safe on rubber parts, good temperature resistance, often supplied with caliper rebuild kits so I take their word for it.
Offline Froglodyte
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #3 on: February 25, 2025, 23:27:46 »
I've got a silicone grease I use for slider pins inside boots like on the Gen 3. For metal on metal surfaces (for instance where the pads run) I use a high temp ceramic grease from Eurocarparts.
That K2 "Silicone" grease isn't listed as silicone anywhere else, the manufacturer doesn't even say silicone, just "synthetic", otherwise that seems like a decent buy.
Offline nigel s
  • Bike: DL650A M2
« Reply #4 on: Today at 04:57:28 »
I use this on sliders and pins, one sachet is enough for all three brakes.
https://www.ebay.co.uk/itm/232360866347
« Reply #5 on: Today at 12:38:55 »
 Thanks all for your responses.     -  Last year on the XJ600 I used a high temperature copper grease and this was nicely slippery. Since then the bike has never been out in the rain and the rubber boots and seals and pistons were new. Yesterday, having not used the bike for six months the front brakes were jammed on. After removing the calipers and cleaning everything I found the grease I used had turned into something like hard wax and the pins were reluctant to move.  A common problem unless they are stripped once or twice a year and why I hate two pot sliding calipers.
I looked at the product recommended by Mr Froglodyte but saw the postage from Latvia was over £9 so I opted for a cheaper free post version (because I am a cheapskate). I considered the small sachet options but having four bikes I opted for a larger alternative.
« Reply #6 on: Today at 14:21:43 »
   Do a search on EBay for K2 grease,just under £9 posted.
Offline Froglodyte
« Reply #7 on: Today at 15:45:06 »
Sorry Brockett - I didn't notice the postage charges !
