Help! Where can I get one of these?
Topic: Help! Where can I get one of these? (Read 217 times)
numptynut
Bike: DL1050 M0
October 11, 2024, 14:04:59 »
The bar end weight kit and spacer mysteriously disappeared from my wife's DL650 (AL2 2012) while parked at Leyburn. I can source the bar end weight kit but not the spacer which goes between the throttle and the plastic handguard kit.
The picture shows clutch lever side.
Does anybody out there know where I can source one?
Cheers m'dears.
Stromtrekking across the universe always going forward 'coz we can't find reverse
Puch MS50V (45 yrs ago!) > Yamaha EW 50 Slider (Daughter's!) > Honda XL125V > V-Strom 650 > Versys 1000 > V-Strom DL1050
Rixington43
Bike: DL1000GT K7
Re: Help! Where can I get one of these?
October 11, 2024, 14:15:01 »
It looks like the knuckle covers on the 650 were always an optional extra and so the longer bolts and spacers to adapt the bar end balancers were only sold as part of the complete knuckle cover kit which is rather pricey;
https://www.motorcyclespareparts.eu/en/Suzuki-parts/5730027841291?_gl=1
If you can measure up the one that's left on the other side then I can check if it's the same dimensions as the ones used on the original 1000 as those were standard on the GT trim and are therefore available as individual components;
https://www.motorcyclespareparts.eu/en/Suzuki-parts/2008-DL1000-v-strom-motorcycles/handlebar?_gl=1
All the other individual parts like rubbers, expanders, washers etc are the same part codes so I'd be amazed if it isn't the same spacer.
You can buy the entire assembly for the older 1000 but oddly, it's more expensive than buying the assembly for the 650 and then the longer bolt and spacer for the 1000 on top. Ah the madness of parts prices
scurrell
Bike: V-Strom Dl1000
October 11, 2024, 15:54:32 »
Try AliExpress. I bought a complete kit for my old DL1000 so there's probably one for the 650, although you could more than likely adapt the DL1000 one.
Rusty Nuts
Manufacturer of iron oxide
October 11, 2024, 16:46:28 »
If memory serves (probably not, at my age) the bolts for the handguard kit are actually shorter than the standard ones, even though there's the extra spacer to go through.
nigel s
Bike: DL650A M2
October 11, 2024, 17:09:36 »
Rusty is right, here is the clutch side bar end and spacer on my ,22 650, the shorter one came with the handguards and is 3" long under the head.The other is the OE.
cooltshirt
Bike: DL650 L6
Reply #5 on:
October 11, 2024, 17:10:04 »
For the bolts I bought these
https://www.ebay.co.uk/itm/383632799945
110mm was actually too long so cut them down, but the supplier does other lengths. They also posted promptly.
They are smarter than the original and easier to work with the the crosshead screws.
Rixington43
Bike: DL1000GT K7
Reply #6 on:
October 11, 2024, 17:16:35 »
Ah I see, they bin off the larger rubber bung and the metal spacer tube on the 650, how odd.
Cheers for correcting my blatherings those who've actually owned one
timangus
Global Biker
Bike: DL650A L2
Reply #7 on:
October 11, 2024, 17:27:26 »
I may have a spare. I lost one once, it just fell off as I was riding and as they were scratched I bought a new set. PM me your details.
