Author Topic: Colour help!  (Read 370 times)
Offline cooltshirt
  • Bike: DL650 L6
Colour help!
« on: September 29, 2024, 16:47:49 »
Not a good day ......... removing wheels to get new tyres fitted and the thing fell over.    :bawl: :angry-banghead:
I had taken plenty precautions to keep it stable ... I think I actually had one jack too many and as something moved it pivoted and fell rather than just moving a couple of mm.
Anyway the tank side panel is damaged and amazingly everything else is just trivial marks.
Question is my bike silver? Googling suggests it is and gray (the other option) is much darker .... more a gunmetal colour
Want to order the right part. Should be available from webike in Japan.
Thanks
Offline Dark-Strom
  • Bike: 2018 Ninja 650
Re: Colour help!
« Reply #1 on: September 29, 2024, 19:45:06 »
Sorry to hear of the bit of bad luck. From Web info yours is metallic mystic silver, the darker silver/grey was on models up to 2015.
There are tank fairing covers of this colour on ebay at £116 delivered atm.
Good luck. :thumb:
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #2 on: September 29, 2024, 20:16:41 »
Thank you I am over the initial upset (I am a drama queen and undeserving of my wife who absorbs it all!) and pleased to hear it confirmed as silver.
At the moment webike in Japan (I have used before) are £100 delivered for the plastic in colour, an S badge, couple of unrelated bolts. I do see that on eBay and elsewhere I can get both sides in gray, used, for a lot less so that is an option to do a kind of colour change!
Thanks again  :)
Offline nigel s
  • Bike: DL650A M2
Re: Colour help!
« Reply #3 on: September 30, 2024, 06:42:42 »
Opps.... It happens :shrug:
I strap the center stand fwd to the engine bars and have bolted a scissor jack onto a old bit of kitchen worktop with a home made fitting that locates on the engine bars ,the further fwd the better for stability...solid as , even with both wheels out and best of all...cost not a penny :icon_wink:
Ho Hum
Re: Colour help!
« Reply #4 on: September 30, 2024, 07:03:08 »
Have a look on the site https://www.colorrite.com/, for the paint colour info.
Simply enter your bike's make, year and model in order to display the paint colour and paint code specific for that model.
For jacking up the front, my method: http://www.vstrom.info/vsri-gallery/gallery/MM/CHASSIS/Fork+Seal+lift.jpg.html. I make use of a swingarm stand to hold the rear in place, when lifting the front end.
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #5 on: September 30, 2024, 09:18:02 »
Thank you for the guidance, very much appreciated. Will get help and get bike securely located. Have pressed the button to get parts from webike.
Onwards.
Offline vstroman
Re: Colour help!
« Reply #6 on: September 30, 2024, 16:03:55 »
Sorry your bike fell over, can easily happen.
another reason it's a lot less hassle to just ride in somewhere and get the new tyres fitted? worth the extra cost.
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #7 on: September 30, 2024, 16:15:01 »
Indeed ........ just wanted to remove the wheels and check for myself that all was in order.
I'm probably going to have to do the fork seal(s) at some point although I have bought and am using this
https://www.ebay.co.uk/itm/156050838992
Definitely improving things..... we shall see.
And of course I have now taken the ratchet strap I have and passed it over the huge RSJ beam in the garage and now have the front end raised securely. A moments work. So I will know in future. They say hindsight is a great gift ...... it appears I am truly blessed. Ho hum.
For me, like many, maintaining my vehicles myself is part of the .... I won't say pleasure, but perhaps satisfaction of ownership.
Offline nigel s
  • Bike: DL650A M2
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #9 on: October 01, 2024, 17:45:25 »
So I got the new tyres fitted and put the wheels back on the bike in a happily drama free fashion.
Everything seems to work and the ABS light goes out (phew!)
Damaged panel refitted with silver duct tape cunningly disguising the damage  :icon_wink: New parts should be leaving Japan about now.
Short test ride suggests I will appreciate the roundness of the profile ........ I guess the old tyres were a bit squared off.
Pics show tyres and a small piece of dense foam found on floor (with AA battery for scale. Is it from the bike and if so where?
Offline nigel s
  • Bike: DL650A M2
Re: Colour help!
« Reply #10 on: October 01, 2024, 18:00:50 »
New Tyres , always nice :thumb:
As to the foam, sorry not a clue ,don't recognise it as being from my '22 650 :shrug:........Keep hold of it .......just in case it keeps the wheels on :grin:
Ho Hum
Offline Rixington43
  • Bike: DL1000GT K7
Re: Colour help!
« Reply #11 on: October 01, 2024, 18:03:58 »
Did you take the side panel off?
Looks like the sort of high density foam that is sometimes stuck on the back of plastic tank shroud panels to stop them rattling or vibrating against the tank.
Doesn't have a groove in the other side does it?
Could be the fuel tank cushion listed as part 4 below;
https://www.motorcyclespareparts.eu/en/Suzuki-parts/4454111j01
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #12 on: October 01, 2024, 22:01:52 »
I've had the panels off and nothing spotted yet. When I next have the fuel tank off I'll check there. In the meantime the trick is not to lose it!  :grin:
Offline nigel s
  • Bike: DL650A M2
Re: Colour help!
« Reply #13 on: October 02, 2024, 05:35:14 »
Ah ..yes ..not losing stuff.
I was looking for two clips to swap the rear rack from my old bicycle to the new one.
No problem , thought I, I DEFINATELY remember putting them somewhere for safe keeping a couple of weeks ago, thinking " I'll need them".
Gone :icon_wink:
Though I have narrowed them down to "in the garage"
Ho Hum
Online mrp192
  • Bike: V-Strom 1050
Re: Colour help!
« Reply #14 on: October 02, 2024, 16:48:30 »
There is one rubber cushion like that inside the panels below the seat towards the front. It fell off on my 2015 bike and I had to stick it back on.
There are numerous cushions on most of the panels and usually the same both sides. They can normally be seen on websites like Partzilla to give you an idea.
Offline cooltshirt
  • Bike: DL650 L6
Re: Colour help!
« Reply #15 on: October 02, 2024, 21:07:27 »
Bingo! Thank you.  :ty: That's it! Identified the part as shown in the pic.
I shall have a look tomorrow.
