Author Topic: ECU Vstrom DL650  (Read 276 times)
Offline Mateusdes
  • Mateus Braga
ECU Vstrom DL650
« on: September 26, 2024, 14:54:09 »
First post here on the forum, does anyone know how to clean or reset the ECU of the DL650 2012? I'm finding mine very square and with some jerks when starting a sudden acceleration and it's consuming 1L/18KM
 :welcome:
-Yamaha YS 250 - 2015-
-Yamaha XVS 250 - 1997-
-Honda CG FAN 125 - 2018-
-Honda XR Tornado 250 - 2008-
-Honda Shadow VT750 - 2007-
Suzuki V-Strom DL650 - 2012
Offline Mateusdes
  • Mateus Braga
Re: ECU Vstrom DL650
« Reply #1 on: October 02, 2024, 20:20:24 »
 :bawl:
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #2 on: October 02, 2024, 21:11:09 »
I feel your pain  Mateusdes but I'm not a mechanic so can't help. I think someone will be along soon to give some advice, I hope so. Good luck and I hope the problem is solved soon.  :thumb:
« Reply #3 on: October 02, 2024, 21:55:15 »
     I think the only way to reset an Engine Control Unit on a Suzuki is with dealer only plug in software.Or possibly it might be the TPS is way out of adjustment,I would try that first to deal with the jerky throttle.
Offline Ian P
  • Bike: DL650 K8, 1976 Moto Guzzi T3 California
« Reply #4 on: October 02, 2024, 22:01:56 »
Hi Mateus,
Reading through your post I think the problem maybe linked to a couple of things.
1. the Throttle Position Sensor (TPS) may be on the way out or need resetting. These can be cleaned and reinstalled which may help. But in my experience it is best to replace with a new one if it does play up.
2. You may have to do a fuel flow test, this will establish if the fuel pump is capable of delivering the correct fuel pressure when the engine is running. If the results of the test are not good then you may be able to get away with just changing the sock filter at the bottom of the fuel pump pick up, these tend to get very dirty and can block up. If that doesn't solve it then you may be looking at a high pressure filter change which is a lot more expensive. I know on the Stromtrooper website a lot of people talk about doing a high pressure filter bypass mod and installing an external filter, but my personal opinion is this is just trying to fix things on the cheap and may bring with it other complications and possible safety issues.
I know on my bike that I had similar symptoms to what you describe and after fixing the fuel pump and changing the TPS it has run seamlessly for 100,000 Km. For your info I get in the region of 27-28 Km/L, but that is in Australia where the speed limits are relatively low and heavily enforced, so the bike is not ridden hard.
If you do a search through this forum there should be lots of posts regarding both issues which should get you on the way.
Hope this is of some help, and good luck with your endeavours.
In the words of Rob Hunter of the Grateful Dead:
"what a long strange trip it's been"
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #5 on: October 02, 2024, 22:10:26 »
I can't imagine an ECU of 2012 vintage has any non-volatile memory for things (basically, disconnect it from power for 30 mins should reset it).
If you're using a lot more fuel than normal, have you checked for air leaks (which the ECU might correct for by injecting more fuel), but also fuel leaks?
These bikes are also known to be a little jerky just off idle, if this bike is new to you it does take some getting used to, unless it's just started?
  • The Doctor 46
« Reply #6 on: October 03, 2024, 00:46:35 »
See! I said there would be someone along soon. There are some good lads on this site, helpful and knowledgeable. Please let us know how you get on with it.  :thumb:
« Reply #7 on: October 03, 2024, 06:21:21 »
Hi ..
Using that amount of fuel its possible you have an air leak as said already. This tricks the ecu into adding more fuel to compensate.
