So having replaced a faulty solenoid a couple of months ago I decided to 'dismantle' the old one and have a look.
Out with the hacksaw and into two pieces.
The bottom half (left bit) has a plunger and a spring which when not energised pushes the small silver pin on the top half (right bit) and that keeps the circuit broken as the piece of copper that it is attached to (just visible) is needed to make a connection between the left and right bigger bits which go direct to the terminals.
When energised the plunger is withdrawn into the body of the bottom half and the silver pin comes down and the circuit is complete.
I'm guessing that the darker piece of copper which looks like it has been hot was making a poor contact and hence an unreliable solenoid.
In other news UI have new fork seals and gaiters ...... guess what's on the to do list
