Author Topic: YSS rear shock.  (Read 150 times)
YSS rear shock.
« on: August 01, 2024, 20:20:02 »
YSS rear shock for sale. This came off my gen 2 (2012 - 2015) but I believe it will also fit the Gen 1 (not sure about the later models). The shock was only on my bike for 1000 miles before I upgrade again so it's like new.
It will come complete with the 'stiffer' spring I had fitted which has,
YSS-56-110-185 stamped on it.
I will also include the original spring that was fitted when first bought, that has,
YSS-56-95-185 stamped on it.
Just for information the 56 is the inside diameter, the 110/95 is the hardness/stiffness in Nm, & the 185 is the length.
The stiffer spring fitted was perfect for the 'larger' rider  :whistle: & once the preload was wound up a bit worked OK with a pillion & luggage.
If you are a lighter rider & won't carry a pillion then the less stiff spring might be worth fitting.
When I say 'larger' rider I am 16 stone (170 kg)
£250 for complete shock + additional spring, & inc postage.
