Author Topic: Anyone got a fix for a slipping screen?  (Read 409 times)
Offline Gillie76
  • Bike: DL650A K9
« on: July 15, 2024, 13:46:33 »
So my bike has an MRA screen on it and the bracket that you adjust the tilt keeps going slack when I ride, resulting in pushing back from the intended setting, no matter how tight I try and get the thumb screws 😫
Is there any hack which can fix this issue? Cheers
Offline cooltshirt
  • Bike: DL650 L6
Re: Anyone got a fix for a slipping screen?
« Reply #1 on: July 15, 2024, 15:50:49 »
Is it a madstad bracket? I do up the lower bolts with a spanner and then tighten the thumbscrews. So if they come loose .... which they do .... then the lower bolts hold it steady. Means you can't adjust without a spanner.
Offline nigel s
  • Bike: DL650A M2
« Reply #2 on: July 15, 2024, 16:29:53 »
The MRA on my Fazer 1000 did that.
In the end I put it in the preferred position then drilled a  tiny pilot hole and fitted a  self tapping screw to each side. No longer adjustable but stayed put.
Eventually replaced it with a Madstad.
Offline Upt North
  • Bike: DL650 L7
« Reply #3 on: July 15, 2024, 16:33:38 »
Like Nidge says, find the sweet spot and lock it in place. Could you drill through the centre hole and put a small bolt through.
Upt.
Offline Gillie76
  • Bike: DL650A K9
« Reply #4 on: July 15, 2024, 17:09:51 »
Thanks. Not sure what bracket it is...here is a pic 😂
Offline nigel s
  • Bike: DL650A M2
« Reply #5 on: July 15, 2024, 17:14:25 »
Madstad.
After a while the tiny fitted washers wear, then you have to do like cooltshirt says.
Though if you turn the knobs round to the inside it can work.
Offline cooltshirt
  • Bike: DL650 L6
« Reply #6 on: July 15, 2024, 17:14:42 »
Madstad.
Excellent bracket in my opinion. Do up the lower bolts tight and that will hold it. Then all the upper ones do is stop it rattling. Once you have worked out the best position, you are unlikely to ever move it again.
Offline Upt North
  • Bike: DL650 L7
« Reply #7 on: July 15, 2024, 17:16:59 »
Could you put some anti slip washers in between the fittings or maybe a rubber washer to grip better.
Upt.
Offline Gillie76
  • Bike: DL650A K9
« Reply #8 on: July 15, 2024, 17:24:21 »
Thank you! I'll get the bottom ones done up really tight then. I wonder if I put a serrated washer on the top ones, if that might help it grip? 🤷‍♂️
Offline nigel s
  • Bike: DL650A M2
« Reply #9 on: July 15, 2024, 17:41:13 »
Not sure  difficult to see in your pic, but they should have a recess for a circlip to stop them coming off. Note knobs fitted on inside here on my 650.
Offline Gillie76
  • Bike: DL650A K9
« Reply #10 on: July 15, 2024, 17:46:11 »
Cheers, I'll have a fiddle around when I've got some time and see what I can do. Thanks for the ideas. I'll post up if I'm successful 🤞😂
« Reply #12 on: July 15, 2024, 18:00:17 »
The earlier versions didn't have the circlips. I lost a screw in a long contra flow roadworks, no way to stop and look for it.
Belville washers may be a better bet than shakeproof, but a slight tweak on the existing fixings should provide enough friction to stop the slipping.
Offline Gillie76
  • Bike: DL650A K9
« Reply #13 on: July 18, 2024, 20:38:22 »
No circlips on mine. I tightened the bottom bolts up as much as I could, then took the thumb screws off one at a time and rotated the rubber washer and put back together with a dot of thread lock. Hopefully get out for a wee ride tomorrow after work and see what happens 🤞
