Author Topic: Clutch lever, excessive vertical play  (Read 669 times)
Offline Gillie76
  • Bike: DL650A K9
« on: July 02, 2024, 09:05:18 »
As per title of post, my clutch lever is significantly wobbly on the vertical axis. I've seen a fix where you can use a brass shim washer to take up some of the play. My question is, is this a safe way to minimise the wobble? I presume you don't want to eliminate the play altogether as it may cause the clutch lever to stick? Has anybody else had this issue or do you just put up with it?
Cheers 🙂
Offline Upt North
  • Bike: DL650 L7
Re: Clutch lever, excessive vertical play
« Reply #1 on: July 02, 2024, 11:15:06 »
It would drive me nuts.
OK....more nuts.
Check for wear on the pin and bushing too. They should be a honeymoon fit.
If all good, a shim and a bit of lube it is.
Upt.
Offline Gillie76
  • Bike: DL650A K9
« Reply #2 on: July 02, 2024, 17:44:08 »
Thanks Upt, sounds like a plan 👍
« Reply #3 on: July 02, 2024, 17:59:02 »
Honeymoon and lube in the same post.  :grin:
Offline Upt North
  • Bike: DL650 L7
« Reply #4 on: July 02, 2024, 18:44:56 »
 :whistle: I knew someone would notice and I wasn't surprised it was Rusty Nuts. More lube required.
Upt.
Offline Gillie76
  • Bike: DL650A K9
« Reply #5 on: July 02, 2024, 18:51:39 »
 lol lol
« Reply #6 on: July 02, 2024, 19:14:11 »
You just had to slip it in there, didn't you.
Offline Gillie76
  • Bike: DL650A K9
« Reply #7 on: July 06, 2024, 22:28:05 »
Sorted today with a 0.5mm shim, what a difference 👍😀
« Reply #8 on: July 07, 2024, 11:50:03 »
I was told: lubricate with oil and not grease. Grease will hold dust and micro grit in the gubbins and act as grinding paste whereas oil will drip, rinse. wash out, etc. taking the dust with it. All levers that pivot on steel pins, like footrests, are oiled and not greased.
Offline Gillie76
  • Bike: DL650A K9
« Reply #9 on: July 07, 2024, 13:36:02 »
Thanks for the info Brockett. I just presumed it was to be greased as it was when I removed the pin in the first place 🙄
« Reply #10 on: July 09, 2024, 07:41:09 »
Did you snap a pix of your mod?
Offline Gillie76
  • Bike: DL650A K9
« Reply #11 on: July 09, 2024, 17:59:11 »
Gert, no I didn't. I didn't think it warranted a pic to be honest! Just a case of slipping the shim in the space between the clutch lever and the holder/bracket
« Reply #12 on: July 10, 2024, 07:28:23 »
My reason for asking for a pix, is so that there is no confusion to anyone, who may in the future be look at this thread for guidance on a similar complaint.
To me, a pix will clarify exactly how and where the shim / spacer was inserted.
As we all know, both the clutch lever, and the gearshift levers are prone to lever slop. The solution / fix to both is either to add a shim / spacer, insert a bushing in the lever, buy a replacement lever or to replace the pivot pin (gearshift) / bolt (clutch lever).
I trust that you can see where I'm going with my request for this additional info...
Offline Gillie76
  • Bike: DL650A K9
« Reply #13 on: July 10, 2024, 08:54:19 »
No worries Gert. Once this persistent rain decides to go away, I'll go back to the bike and provide some pics with an explanation 👍
Offline Upt North
  • Bike: DL650 L7
« Reply #14 on: July 10, 2024, 09:19:49 »
We'll expect a picture by October then!
 :groan:
God yesterday was wet. At the moment it's worse than last year and that was dire.
 :dl_soapbox:
Upt.
Offline Gillie76
  • Bike: DL650A K9
« Reply #15 on: July 12, 2024, 16:18:38 »
How I fixed my wobbly clutch lever...please note this is for vertical play and not actual clutch cable adjustment.
1. Remove the 10mm nut and washer from the top of the clutch lever and take off the hand guard if you have one.
2. Using a 10mm socket on the top of the pivot bolt and a 10mm ring spanner on the bottom nut, remove the bottom nut, washer and spacer, being careful not to drop any parts!
3. Remove the pivot bolt upwards, inspect and clean all parts and lever. You should see space between the lever and the bracket which is causing the vertical slop.
4. Using an appropriate M8 shim washer (mine took a 0.5mm) insert at top of lever and move lever back into place to check the tightness of fit. The shim has to take up enough slack to reduce unwanted movement, but crucially, not too thick in order to allow the lever to return to its original position.
5. Once you have determined the correct thickness of shim, lubricate all parts and refit, always checking the lever has free play back to its original position. Enjoy your non-wobbly clutch lever 😀
Offline Ambergnat
  • Bike: DL650A L2 Very Grubby (now ageing) Pearl White 2017 BMW S1000XR SE in Blue
« Reply #16 on: July 12, 2024, 22:03:04 »
Nicely done sir, well explained and excellent pics.
This might end up being moved to the Top Technical Posts because it is a perennial issue and is soooo easy to solve if you know how.
Cheers.
It's not paranoia, it's just reality on a finer scale... Strange Days - 1995
To catch a bus - first you must think like a bus  -  Dave - Last year
« Reply #17 on: July 13, 2024, 08:00:36 »
Cheers for your write-up and your posted pix.
While the grip / knuckle / hand guard anchoring point may differ for various reasons, depending on the type / brand of grip guard installed or absence of a grip guard, the clutch lever shimming process would mirror the steps in your guide.
Your post is a good reference / guide for anyone wanting a solution for their clutch lever slop.  :thumb:
