Ahh OK then that is it then , I was thinking maybe it was todo with something from that issue , but that would be it then, I’ll do the diagnostics but Yh I suppose it would be from that 😑 so the little things you can plug into them that we can get from fleebay, that will turn out the light but the actual problem won’t be fixed right? So the sensor is showing me that there is an issue with the emissions , would this later down the line cause an issue if not rectified?
