Author Topic: Muffs for the Strom  (Read 765 times)
Offline The Sleeper
  • Bike: DL650A K7
Muffs for the Strom
« on: October 19, 2023, 15:57:49 »
Afternoon all,
Hoping someone might be able to help me. I commute 100 miles a day for work. After lots of searching for waterproof winter gloves (which are not heated) there really are none that will tick what I need.
Therefore I'm looking to get some bar muff (Oxford, tucano etc). Everything on the bars is factory standard like mirrors etc.
Has anyone fitted a pair which work?
I have the hand guards so wind pushing should not be an issue assuming the muff go over those as well.
Offline Dark-Strom
  • Bike: 2018 Ninja 650
Re: Muffs for the Strom
« Reply #1 on: October 19, 2023, 23:01:31 »
I did toy with these on my 2012 Glee, think they were tech7 make.
Drilled a hole for the bar end bolts to go through and a few rubber washers from memory.
Didn't have handguards which would have supported them better, so might be worth a try?
Offline nigel s
  • Bike: DL650A M2
« Reply #2 on: October 20, 2023, 05:08:47 »
Not a fan of muffs,have tried them but could not get on with them.
Flap flap flap
But with heated grips/handgaurds and these
https://www.infinitymotorcycles.com/product/richa-street-touring-gore-tex-mens-gloves?gclid=CjwKCAjwp8OpBhAFEiwAG7NaEkIjz46folZdyXFHTCZ04LGcyZWplxFrJBOpomwhF7HG1i_cAVjslhoCQfkQAvD_BwE
I have found I don't need them.
You could do the washing up in them and not get wet .
Used for 3 winters and 40,000 miles ,still my goto glove if it is wet out.
Offline Dark-Strom
« Reply #3 on: October 20, 2023, 06:54:27 »
Must admit I've never had guards or heated grips on a bike to date, horses for courses  :thumb:
Offline mrp192
  • Bike: V-Strom 1050
« Reply #4 on: October 20, 2023, 17:29:38 »
I’m not sure how to search on here very well, but I remember a thread about someone having success with a set of muffs that were made of neoprene. Apparently didn’t suffer from sagging in the wind blast.
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #5 on: October 23, 2023, 02:46:28 »
If you go to the top right of the page you will see a search box. Type in, bar muffs, and you will find lots of threads mentioning them. Apparently the cheap eBay ones do fit over hand guards. I had them on a ZX10 (without hand guards) years ago when we had a very cold winter. At that time they were one of the best accessories I had ever bought a bike, they do work once you get used to them, I wore summer gloves under mine.  :thumb:
Offline Robotstar5
  • Bike: DL650K5
« Reply #6 on: October 23, 2023, 12:28:52 »
Got it made these days with heated grips, muffs etc., when I started riding in the 70's my mum knitted me some thick wool mittens which I used inside some Belstaff waxed cotton mitts, I think having fingers touching instead of separated by gloves helped.
« Reply #7 on: October 23, 2023, 14:30:42 »
Quote...... "I’m not sure how to search on here very well"
Quote...... "go to the top right of the page you will see a search box"
Use the search box indicated by the circle, that will search the whole site from whatever thread/board you are on.
The one, top right, marked with the X will only search the board you are on.
  • The Doctor 46
« Reply #8 on: October 23, 2023, 14:35:41 »
Thank you Mick, I've learnt something.  :thumb:
« Reply #10 on: October 23, 2023, 19:14:35 »
Doc, I'd been a member of the forum for 6/7 years before I realised the difference!!  :shy:
If you go to the 'home' page the top right search will look at the whole forum.  :thumb:
Offline chrisj
  • Bike: None
« Reply #11 on: October 27, 2023, 18:46:06 »
I have a set of Givi TM241 muffs, which fit straight on over the handguards in seconds. Really effective.
https://www.xlmoto.co.uk/product/givi-tm421-universal-hand-protectors_pid-PIA-150981
