Givi S310 Trekker Spots
Topic: Givi S310 Trekker Spots (Read 592 times)
Ian T
Bike: DL650 L3, BMW K75s. Ural 750 outfit.
October 17, 2023, 09:34:16 »
Hi
Does anyone happen to know the draw on these. I have a pair on but thinking of adding some other stuff and would like to work out the black magic stuff.
Ian
Fat Rat
Administrator
Bloke/Geezer/Fella
Re: Givi S310 Trekker Spots
October 17, 2023, 09:41:56 »
I seem to remember that these are 50 watts each, that is a fair bit of load. When I had them fitted, I experimented with swapping the halogens for LED lamps, but found them to be unreliable.
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
Upt North
Bike: DL650 L7
October 17, 2023, 11:03:10 »
https://www.ebay.co.uk/p/20030669645
Don't know if this is correct.
But that's a lot of extra from the charging system.
Barbel Mick
Bike: 800RE
October 17, 2023, 11:50:05 »
Yes 50w each = a draw of 4 amps each.
If I've not got much running on the bike, other than the chain oiler & Sat Nav my 650 still shows 14volts output on the voltmeter.
They now do an LED version of a similar unit. If you want to part with your hard earned?
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/548177
Upt North
Bike: DL650 L7
October 17, 2023, 15:59:43 »
How much?
That's a lot of full english Mick.
Barbel Mick
Bike: 800RE
Reply #5 on:
October 17, 2023, 22:01:46 »
& a lot of petrol to ride out for them!
Ian T
Reply #6 on:
October 18, 2023, 07:06:17 »
Thanks everyone.
Fat Rat I have seen from other posts that you had a go at an LED bulb but with little success, anyone had another dable at a conversion.
Ian
Barbel Mick
Bike: 800RE
Reply #7 on:
October 18, 2023, 07:47:15 »
Yes, I did. I couldn't get one short enough to fit into the recess. The bulb lies at right angles & all the LED ones I tried were too long by a few mm to fit in.
I did force one in to try it but the light output was shocking except if you looked at it from one specific angle!
Ian T
Reply #8 on:
October 18, 2023, 10:58:48 »
Thanks
Much appreciated.
Think I’ll sack off that idea then.
Ian
