Quote removed
Ahhh! OK 😕 that can be this weekends Job! So my bike is up and running now it was basically all the rain water inside the hole for spark plug took off the ht cap and was full of water , I think because that front one is hard to get to whoever last changed the plug just tightened it finger tight and didn’t get the ht cap on properly , I ended up taking off the radiator so I could get in there proper and tighten it up properly , a bit of messing around but I’m starting to know my bike threw doing it , so as I stated I now have to oxygen fi light c44 but I could probably be 100% sure that it would be something from the works I have been doing because it was not showing a few days ago when I started all fault finding,
Where abouts is the c44 sensor located exactly ? Is it behind the left back panel ? If it is I wouldn’t have touched it because I was up the front end of the bike, could something else have knocked it out? I will look in to how to check the fuel starvation issue like I say I’m a complete novice but I’m keen and I’m educating myself daily , reading, YouTube , and forums … thanks for everyone’s help
