Author Topic: Clutch lever pivot bolt  (Read 1020 times)
Offline Ian T
« on: October 07, 2023, 14:49:22 »
Well I have stripped this bike down to the frame engine and wiring harness left.
Done all be doing bits, changed all the changing bits and fluids etc.
Cleaned it to within an inch of its life.
Put it nearly all back together except the front cowl and air box, next jobs.
And I’m buggered if I can find the clutch pivot bolt.
Madness I have tried to be very careful and not loose anything and just this damn bolt.
Looking at a schematic it shows a bolt but that would not allow for fixing the OEM hand guards on.
The brake pivot bolt does as it has a threaded female part on top.
Can anyone shed a bit of light onto where I can get one or if you have an old one lurking that I could buy.
Ian
Online Rusty Nuts
Re: Clutch lever pivot bolt
« Reply #1 on: October 07, 2023, 15:47:24 »
Were handguards fitted when you broke it carefully disassembled it? There's a replacement bolt that comes with the guards, different from the standard one. Look for a similar but longer one in your pile of bits carefully catalogued Ziploc baggies. I think the shouldered part is the longer bit, allows passing through the plastic and then the clutch lever,
Offline Upt North
  • Bike: DL650 L7
« Reply #2 on: October 07, 2023, 16:15:37 »
I have seen fitting kits from China on ebay.
When you find the original it'll be with my Pan speedometer drive screw.
Where do they go? It's a mystery.
Offline Ian T
« Reply #4 on: October 07, 2023, 17:50:58 »
Quote removed
Yup that’s the bugger lurking on the right.
Not going to buy that lot though.
Thank you very much for the lead
Ian
Offline Ian T
« Reply #5 on: October 07, 2023, 17:53:56 »
Ha ha you are quite right, it’s a mystery. Normally I have things left over this time everything has gone back nothing spare except this pivot bolt which eludes me.
I had an ST 1100 once. Wonderful bike. Probably the best bike I have ever owned. Brought it new on an S plate I think.
Ian
Offline Ian T
« Reply #6 on: October 07, 2023, 17:57:05 »
Yup hand guards were fitted from new.
I always carefully dismantle, I have three different sizes of hammer.
My carefully catalogued zip loc bags, also known as little piles all over the garage have all been used up nothing left.
I think someone stole the bolt when I was asleep.
Offline Ian T
« Reply #7 on: October 07, 2023, 18:11:10 »
Well I’ve just tried every Ali Express or what ever it is called advertising the full hand guard set with mounting kits.
All no longer selling or sold out.
How hard can it be.  :dl_smiley_banghead: :dl_smiley_banghead:
Online Rusty Nuts
« Reply #8 on: October 07, 2023, 18:28:18 »
Nothing left? I always seem to have at least one "pocket screw" left, it usually announces its presence by tapping insistently on the glass door of the washing machine.
Offline nigel s
  • Bike: DL650A M2
« Reply #9 on: October 07, 2023, 18:40:00 »
I've heard that line somewhere before ?
Online Rusty Nuts
« Reply #10 on: October 07, 2023, 18:41:40 »
Shirley not?  :whistle:
Offline nigel s
  • Bike: DL650A M2
« Reply #11 on: October 07, 2023, 18:45:04 »
Offline Dark-Strom
  • Bike: 2018 Ninja 650
« Reply #12 on: October 07, 2023, 19:25:13 »
We fitted hand guards to my Sons L2 earlier in the year. Bought them from Fowlers but they only do the one kit for all now based on 2017 onwards with no info on how they fit earlier models (no longer middle bolt) a bit of web searching later and we sussed it but what a balava.
Anyway, just thought you could try Fowlers? Good luck 👍
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #13 on: October 08, 2023, 02:32:24 »
Ooooh, EDIT:
The standard pivot bolt hasn't changed between 2013 and 2018, and the 2018 650XT version has the hand guards as standard. The bolt is £18 from Fowlers, but you can get it from Webike Japan for £7 + £12~ postage, so if you need to get any more bits for it like the accompanying spacer, washers and nuts, or other OEM parts, you might find that works out cheaper. For instance the  pivot + complete set of washers, spacer and nuts comes to £24 delivered. My last order was with me in 3 days (brake pad shims and some other small bits that are silly money here, but cheap as chips in Japan). https://japan.webike.net/products/24727342.html
https://www.motorcyclespareparts.eu/en/Suzuki-parts/2018-dl650axa-v-strom-motorcycles/handle-lever-dl650xa-dl650xaue
https://www.motorcyclespareparts.eu/en/Suzuki-parts/2018-dl650axa-v-strom-motorcycles/knuckle-cover-dl650xa-dl650xaue
The bits are spread over these two diagrams, copy the part numbers into the Webike Japan search box, and put a hyphen in the centre, so for instance "083192106B" becomes "08319-2106B", the search will then recognise it.
The only thing I cannot confirm is if you need both sets of bottom nuts from both diagrams at the moment, I will be able to in the morning! It looks like it from a previous hand guard install instructions: http://cypressgraphics.com/motorcycle/hand%20guard%20install.pdf (Courtesy of Stromtrooper).
Offline Ian T
« Reply #14 on: October 08, 2023, 07:03:52 »
Wow
That’s fantastic and thank you very much. The fitting diagram is also extremely helpful.
Think I’ll spend the day rummaging through me box of bolts then it looks like I will have to bite the bullet.
Ian
Online Rusty Nuts
« Reply #15 on: October 08, 2023, 07:30:29 »
The missing bolt will turn up 20 minutes after it's replacement arrives. Stride into the garage with an empty jiffy bag, announce loudly " my new clutch pivot bolt is here!" then lurk quietly in a dark corner. The miscreant will then show itself.
Offline Ian T
« Reply #16 on: October 08, 2023, 09:03:41 »
Just finishing me coffee then bag in hand I will stride
Offline Dark-Strom
« Reply #17 on: October 08, 2023, 19:36:02 »
 lol
Offline duck-strom
  • Bike: DL650XT
« Reply #18 on: October 08, 2023, 19:41:07 »
Yamaha FS1E >Yamaha DT125> Yamaha DT175 > CB400N > Yamaha XJ650 > SV650s > Aprilia SL1000R >> DL 650XT
Offline MilozFolly
  • Bike: DL650 L3
« Reply #19 on: October 10, 2023, 18:03:02 »
From China, could not find these bolts separately.
https://www.ebay.co.uk/itm/184852944349?
hash=item2b0a1815dd:g:X9gAAOSwFWhgq11F&amdata=enc%3AAQAIAAAA4JQqPEDY4Pw0dzZn59i3Ij4a36u2qN8gaePCRXV9nr6GtAQwPlSBd5wC7jpolMlFpOmbOeuYiwfQn3jCWpVhAsh42IBCJIl2k1p0NolF5XK29%2BwIgC9z99FxSfNCm9g2HtkKjk7qj7w4IpsFXl0M%2B5knPZGlP2KgC56HoMqC88CMtrwB8YlERwdxze0Rtc10ZGZFFEFycUy3FGYRa5Njudo%2FPM7dWi1c67HOtvJ3DY1e3LG5XunIN0Y4CaryZRXCbzmcia%2FD824FHXBudRRdAgQ4mkqeCZv909PLcEvNud9v%7Ctkp%3ABFBMvJ6rr-Fi
Thankyou for that. Exactly what I needed. I'm fed up of my bodge job 😁
