Author Topic: Just done 15 k service  (Read 558 times)
Offline cl1ve2004
  • Bike: DL650 L8, FZS600 2003
« on: October 02, 2023, 20:28:13 »
As title says, on 2018 AL8 strom 650,
Valve check, coolant change, plug change, clutch h adjusted etc..biggest pain was refilling coolant and getting rear cylinder spark plug in..no valve shims needed changing, really pleased as never done a twin before :fix:
Offline pichulec
  • Bike: KTM 1290 SAS
Re: Just done 15 k service
« Reply #1 on: October 02, 2023, 21:00:02 »
Well, in my 2005 1K valves were still in spec at 80k miles so it is a waste of money to do valves at this mileage.
« Reply #2 on: October 02, 2023, 23:22:06 »
Well it never hurts to check and if you can do it yourself costs very little. My 1000 needed nothing at 15k but needed all 8 valves adjusted at 30k, a friends 1000 needed two exhausts shims at 15k.
« Reply #3 on: October 03, 2023, 11:13:52 »
I've now had mine checked three times, the first one was free as they were done on a recall at about 12k. The second two I paid for, one at 32k when they were OK but at 52k four were out!
I didn't consider it a waste of money on the second check when they were in spec & if I had tried to wait until 80k I might have needed more doing to the engine that having four shims changed!
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #4 on: October 03, 2023, 11:18:28 »
You can't put a price on the warm fuzzy feeling of doing a job yourself, saving the labour cost (biscuits not withstanding) and then riding around knowing it's been done.
 :fix: :text-bravo:
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #5 on: October 03, 2023, 12:27:32 »
My bike always gives me the feeling like I have saved a life even after an oil and filter change. It seems to run better, do more mph, run quieter, go faster and even stop faster. It's all in the mind I know but yes, it is that warm fuzzy feeling that I pay for. It's worth it and definitely will make the bike live a little longer. My problem is documenting all the love I give her, I often forget.  :thumb:
