Author Topic: BlackLabs site closed down  (Read 532 times)
« on: September 29, 2023, 07:45:37 »
For those who have made use of the BlackLabs maintenance guides in the past, his site has closed down.  https://www.stromtrooper.com/threads/black-lab-adventures-com.443297/
In the event of anyone needing to reference any of BlackLabs maintenance guides, a few have been saved in pdf format, to https://www.stromtrooper.com/forums/black-labs-maintenance-walkthroughs.328/ .
The titles of the pdfs that can be downloaded from the Stromtrooper site are:
Start Switch Maintenance - Black Labs
Replacing A Clutch Pushrod Seal and Countershaft Seal - Black Labs
How I Adjust The Steering Stem Bearings - Black Labs
2007 DL-650 Valve Check and Adjustment - Black Labs
Replacing The “Cush Drive” Absorbers - Black Labs
Fabricating Homemade Swingarm Removal Tools - Black Labs
Changing The Motor Oli With A Skidplate Installed - Black Labs
Plugging a Tyre - Black Labs
Steering Stem Bearing Replacement- Upgrade - Black Labs
Replacing Front Fork Oil Seals - Black Labs
Rebuilding The Water Pump - Black Labs
