Author Topic: Tank coming off..What else could I do?  (Read 695 times)
Offline Aberdeen lad
  • Bike: DL650XT L6
« on: September 28, 2023, 09:31:16 »
Hello folks. I’ve ordered a new air filter for my 2016 650 v-strom xt, so tank is coming off I’ll admit am a little bit daunted by the task. Anyway what else can I take care off if the tank is coming off, I thought I could perhaps drain and renew coolant and I believe there is 2 spark plugs at the back I could inspect or change out anything else?
Thanks in advance
Chris
Online Rixington43
  • Bike: DL1000GT K7
Re: Tank coming off..What else could I do?
« Reply #1 on: September 28, 2023, 09:33:47 »
A good clean and re-lube of all the throttle linkages is a good idea whenever the tank is off.
Offline Ian T
« Reply #2 on: September 28, 2023, 12:14:17 »
Given my recent troubles I second and third that. You don’t want em seizing up.
Ian
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #3 on: September 28, 2023, 14:28:39 »
A good clean up of any electrics that are now accessible.
« Reply #4 on: September 28, 2023, 16:13:43 »
And add some old bicycle inner tube over the electrical connectors above the radiator to help keep the water out.
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #5 on: September 28, 2023, 22:10:11 »
Inspect the bottom of the tank flanges for rust. I touched some of mine up with Hammerite after a quick application of the rust converting stuff.
Also check your airbox is seated properly before you button everything back up, and that the TB's are actually perched into the rubbers.
