Author Topic: What have you done today  (Read 35486 times)
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4.
Re: What have you done today
« Reply #840 on: April 02, 2025, 19:09:47 »
Thank you again Rixington43, I'm going to order them now and if just a clean and re grease is all that is required then I'll keep them until they are needed. Nothing lasts forever.  :thumb:
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #841 on: April 02, 2025, 19:25:52 »
No worries Doc, happy hunting.
If you don't have one already then I'd recommend adding this to your garage.
Makes the job much easier;
https://gbmotorcycleproducts.com/Suzuki-DL1000-v-strom-2002-2014-steering-stem-nut-socket/
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #842 on: April 02, 2025, 20:20:24 »
For reference, this was the state of mine at 31k.
Top was as smooth as a babies bottom, bottom on the other hand was considerably rougher than the bench of a careless welder 🤣.
I reckon it took half a day to do the switch out  from start to finish having never done the job before. Our ratio is about 2 brews per hour as well 😜.
« Reply #843 on: April 02, 2025, 23:05:11 »
On my 2014 model I'm still in the original head bearings at 46k miles. I clean and grease every few years.
 Also in my opinion there's no need to replace the rocker cover gaskets and washers at 15k, I've had mine off twice now and till on the original 's and will go one more time before replacement.
  I've taken to replacing the centre cylinder spark plugs every valve check as there a pig to get to do while I'm in there I might as well but the side plugs I replace every other check as if the bikes runs funny I can change them in minutes.
 I think you should looking for another mechanic Doc!
« Reply #844 on: April 03, 2025, 11:37:20 »
Doc if it's not too late & you've already ordered them then I've had this information on record for a while now.  :thumb:
Steering head (DL650 & DL1000 all years):
Size: 30x55x17mm - 2 needed
Suzuki #: 09267-30010
Common #: None
Seal #: 51644-12C00 - 2 needed
The OEM steering ball bearings may be replaced by tapered roller bearings no. 32006 (2 pcs.), if you wish to go this way.
You will pay a bit more than Rixingtons suggestion if you go with a 'named' make like KOYO, SKF or Timken but they will last.  :icon_wink:
Offline 2112
« Reply #845 on: April 03, 2025, 13:51:14 »
My new internal sun visor arrived for my HJC 90s helmet. It took longer to unpack than it did to fit! An absolute doddle to remove & install, simply pull it out of the retaining clip at each end then click it back in place - simples  :thumb:
