Basic information
Topic: Basic information (Read 513 times)
Robbo1958
Bike: DL650 K6
Basic information
September 18, 2023, 12:32:45 »
Hi blokes, apart from the +&- leads, what else MUST be connected to the battery
sjrainsford
Bike: DL650 L4 and 2008 Vespa GTS300 Super
Re: Basic information
September 18, 2023, 12:58:47 »
As standard, just those leads.
There may be extra cables if other accessories have been added, like heated grips for example.
Upt North
Bike: DL650 L7
September 18, 2023, 13:19:46 »
Like the man said, "nowt".
The Doctor 46
The Doctor 46
Bike: DL1000A L4. DL650 L2
September 18, 2023, 19:05:51 »
If you have other leads connected to your battery they will be to accessories like heated grips, spotlights etc. They could even be running to a charging connector for an optimate or similar. All those things except the charging lead would be better run through a fuse box so as they will switch off with the ignition.
Brockett
Bike: 2022 Moto Guzzi 850 V7 special in blue, 2022 850 V7 Stone in darkest black, 1998 XJ600n in red. 2021 Royal Enfield 500 Classic stealth.
September 18, 2023, 20:30:55 »
A dodge I once saw on a Ducati to supply heated grips. The bike's battery was fitted with an optimate charging lead. The heated grips supply lead was fitted with the same plug as the charger. So the rider can remove the charger and plug in the grips as they'll not both be needed at the same time. I used that idea to supply power through a relay for grips and satnav. Saves having more than one additional connection at the battery. However if anyone is going to do this you must pay special attention to polarity as it's easy to get it wrong.
Youngman
Bike: DL650 AL21, CBR954 '03
Reply #5 on:
September 18, 2023, 23:22:23 »
Trickle charger on the Fireblade as it eats its little battery. Nowt on Strom and I've had 'em for ages.
It's difficult to soar with the Eagles when you're really a Turkey
Basic information
