Hello, I have realised today that my front brake light doesn't work. But, the problem is that rear brake light does work. I have checked the switch, switch is OK. I tried to bridge the cables together, still no brake light. When I press rear brake pedal then brake light coming up. I suspect cable from the front is torn or disconnected somwhere. Do you blokes have any idea where under the seat I can check continuity of that front brake switch cable?? Also how this operate? is it ground being split when the switch is pressed??
