Have a look at the two negative cables coming from the battery,the heavy one goes to the main earth on the engine,the smaller one is the rectifier negative back to the battery,there is a coupling about halfway between the rectifier and the battery,make sure by splitting the connector that everything is OK inside.Good luck,it’s a pig to get to.
