Author Topic: C61 Fault code on DL0150  (Read 491 times)
Offline Paul O Connor
  • Bike: DL1050XT M0
« on: July 20, 2023, 13:55:05 »
Anyone know what fault code C61 relates to on a DL1050?
Offline sjrainsford
Re: C61 Fault code on DL0150
« Reply #1 on: July 20, 2023, 15:42:12 »
As far as I can make out, C61 relates to an issue with the PAIR circuit.
This stands for Passive air injection reburn, it's a solenoid operated system and would normally be around the air box.  No idea on a 1050 though.  That would happen after disconnection of or failure of the solenoid valve.  Got a plug accidentally unplugged for instance?
  • Bike: DL1050XT M0
« Reply #2 on: July 20, 2023, 16:29:57 »
Thanks that's is what I thought, nice to get it confirmed.
  • Bike: DL1050XT M0
« Reply #3 on: July 21, 2023, 10:28:13 »
Do you know once the fault is repaired should the fault code automatically clear of does it need to be reset? And if so how do I reset it without bring it to a dealer.
« Reply #4 on: July 21, 2023, 14:36:54 »
Once repaired the fault light should disappear however, the ECU will store the fault .
