There have been a few posts on here about owners having problems when alarms have been removed!
Although you have said you have cut the splices & left the loom intact, it is possible that somewhere on the loom the alarm wiring may have required a jumper/loop in a connector to be removed that you haven't replaced?
Here's a couple of links to read that may help....
https://www.v-strom.co.uk/smf/index.php?topic=39072.msg400318#msg400318https://www.v-strom.co.uk/smf/index.php?topic=39009.0Under 'normal circumstances' if there is CHEC on the screen the bike won't turn over. The only time it will turn over is if the voltage is too low from the ECM to the display.
If you have CHEC showing then the fuel pump will not prime.
There is a search button on the forum so if no luck with the above use it to look for more 'alarm removed' or 'CHEC on display' posts.
Please let us know what you find, it all helps others who find themselves in the same situation.
Just realised this is in introductions, could a mod move it to somewhere more suitable please.
Richard, then you can go back to introductions & introduce yourself.
