LED tail light bulbs DL1000
Topic: LED tail light bulbs DL1000 (Read 503 times)
pichulec
Bike: KTM 1290 SAS
May 11, 2023, 21:39:13 »
Hello. Can someone recommend good red LED taillight bulbs? Also, how difficult is to swap them as I know the access to the rear light is not the easiest..
nigel s
Bike: DL650A M2
Re: LED tail light bulbs DL1000
May 12, 2023, 04:17:32 »
My ''22 650 has led tail light as std would the unit fit yours?
pichulec
Bike: KTM 1290 SAS
May 12, 2023, 05:17:49 »
Mate, just want a bulb, not whole unit 🤣🤣🤣
nigel s
Bike: DL650A M2
May 12, 2023, 05:58:29 »
ahh,no problem ,sorry I can't help with the bulb
Gert
May 12, 2023, 07:47:41 »
I'm curious, any particular reason why you want / opt for red LEDs for the brake lights? Are the stock brake light bulb not clear bulbs?
pichulec
Bike: KTM 1290 SAS
Reply #5 on:
May 13, 2023, 04:27:53 »
Simple answer Gert, power draw. Red led will be even more visible than stock too.
Gert
Reply #6 on:
May 13, 2023, 08:15:15 »
I would have thought that the clear bulb would be a brighter through the red lens cover.
I recall doing a mod to create a reflective surface on my 1st gen turn signals, with the info found on
https://www.DL650.org/photos/pbsoluces/lokiki/clignos/index.html
. I also tried a higher wattage tail / stop light combination to be more visibe to the tail-gating, while trying to prevent any bulb heat damage from the stop light lens cover. The orange / red bulbs didn't seem to help back then.
pichulec
Bike: KTM 1290 SAS
Reply #7 on:
May 13, 2023, 09:26:25 »
Well, will see. Ordered 2x for a try. For the interested, It is P21/5W 1157 LED.
Gert
Reply #8 on:
May 14, 2023, 07:47:36 »
I keen to hear whether the red coloured LED would be the similar to the OEM or perhaps brighter.
