Author Topic: splutter 2500  (Read 520 times)
Offline chunky
  • Bike: DL1000GT K6
splutter 2500
« on: April 11, 2023, 19:16:25 »
hi    can anyone point me in a more specific direction regarding a splutter at 2500 revs  in any gear.  many different potential causes found on searching
before I start throwing money around on this that and the other
cheers in advance
Re: splutter 2500
« Reply #1 on: April 11, 2023, 20:03:31 »
Spark plug / HT lead
Re: splutter 2500
« Reply #2 on: April 11, 2023, 20:37:19 »
I had this issue on my old K6 GT, it's a known issue
After trying lots of different ideas, none of them cured the issue.
I finally bit the bullet and fitted a power commander and had a custom map made up on a dyno.
It completely transformed the bike and was worth every penny.
I know others have had some success by fitting TRE , this is far cheaper but not as good as a power commander.
Offline chunky
  • Bike: DL1000GT K6
Re: splutter 2500
« Reply #3 on: April 12, 2023, 19:11:48 »
had a faulty coil    replaced that       and fitted new plugs.
still there though
Offline nigel s
  • Bike: DL650A M2
Re: splutter 2500
« Reply #4 on: April 13, 2023, 06:20:13 »
back to basics I'm afraid. did you change anything prior to splutter.
check safety cut outs on clutch and side stand,and wiring leading off to loom
air leaks/ blockages on intake and exhaust .
check anything recently disturbed even if it was something you just moved to get to something else
how standard is it
will it rev through sputter or is it just when you hold 2500 revs
more info needed
Offline Tigerjohn
  • Bike: '17 DL650, CB500X, CB500F, R1200R, RE Scram
Re: splutter 2500
« Reply #5 on: April 13, 2023, 19:27:25 »
How's your air filter?
Have you possibly picked up some dodgy fuel?
Get the WD40 out and spray all connections you can get to.
