Author Topic: Headlight removal DL1000.  (Read 512 times)
Offline pichulec
  • Bike: KTM 1290 SAS
« on: April 08, 2023, 02:54:47 »
Hi. I tried to find manual how to remove headlight in DL1000 but so far I did not find any. Can you give me advices if anyone done it in the past?
Re: Headlight removal DL1000.
« Reply #1 on: April 08, 2023, 07:46:23 »
From memory the headlight unit is attached to the front cowel and can be removed complete by removing maybe 4 or 6 screws that holds it all to the main stay / frame.
All this can be done after removing the two side panels inner clock surround and screen mount.
Also, depending on what crash bars you have , they may need to be removed in order to remove your side panels.
While it's all apart, you may want to take the opportunity to clean up and paint the main frame / stay as they tend to rust.
« Reply #2 on: April 08, 2023, 09:35:21 »
While not a Vee, a thread that may be of interest that contain some pix on the front end tupperware removal, http://www.DL650.org/photos/pbsoluces/judas/tetedefourche/index.html.
  Once the crown / cowl framework has been removed, you should be able to work out how to unbolt the physical headlight casing.  Also have a look at parts list, https://www.partzilla.com/catalog/Suzuki/motorcycle/2005/v-strom-DL1000/headlamp
   Though I have not yet attempted to remove the cowling a complete unit, I under stand from https://www.vstrom.info/Smf/index.php/topic,10932.0.html, that it can be done.  I prefer the long method and snap pix to help with the reassembly.
   And the steps wrt the fuel tank removal, https://www.vstrom.info/Smf/index.php?topic=7566.0
Offline pichulec
« Reply #3 on: April 08, 2023, 10:37:56 »
Do the screen bracket need to be removed? I know I have seized bolts there...
« Reply #4 on: April 08, 2023, 13:50:36 »
Yes , I believe so ...
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #5 on: April 08, 2023, 19:21:07 »
How far is it from Bedfordshire to Saffffffff London? Kwackboy seems to know exactly what to do and with the help of Gert, it should be sorted in no time.  :thumb:
Offline pichulec
« Reply #6 on: April 08, 2023, 19:57:51 »
I rather to do it by myself (learning exercise) ;)
« Reply #7 on: April 08, 2023, 20:09:51 »
Best way to learn ..... and save money  :icon_wink:
