Slightly off the subject,I have used a headlight relay on both of my Vstroms and since the first headlight problem in 2014 have had no problems whatsoever, the relay takes all of the heavy load away from the connector block under the tank,the starter switch,and dipswitch,all they take is the relay switching which is minimal.I think Bigpie still makes one.Definitely a good investment,I had the tank off recently and there was no sign whatsoever of any heat related corrosion on the large connector.Plus as I have a Scottish ancestry the price is very attractive (that means cheap in Yorkshirespeak).
