Author Topic: Snatchy throttle  (Read 619 times)
Offline Pluto
  • Bike: SV650
Snatchy throttle
« on: March 17, 2023, 07:37:44 »
There's the idea of using the rear brake to blend when lifting off and mention of nyogel under the throttle body/bars to 'grip' and slow down the action.
Anything better?
Caveat... bike has been stood for six months so possibly it's old fuel and just needs a couple of full tanks of premium 99?
Offline Mark Shelley
  • Bike: GW250 SV650N
Re: Snatchy throttle
« Reply #1 on: March 17, 2023, 22:00:13 »
Not sure what you mean. Do you mean the twist-grip sticks a bit, making the action snatchy?
Offline Pluto
  • Bike: SV650
« Reply #2 on: March 17, 2023, 22:00:58 »
That's a better description
« Reply #3 on: March 17, 2023, 22:03:16 »
I had this. There was a recent thread about it. I will try and find it.
Offline purplebikeunicorn
  • Bike: DL650A L7
« Reply #5 on: March 18, 2023, 01:30:05 »
I too had a sticky throttle, not only did I have some crap under the throttle tube, but the linkage was also a bit grimey (including a cable end seized in the TB). It would get worse the hotter the bike got.
A liberal application of WD40 to all the moving parts, plus one-seizing the cable end, made it butter smooth, and it's really really obvious that it's made a difference. You can also check your throttle free play and cable tension is correct, too tight and it can feel sticky.
« Reply #6 on: March 18, 2023, 06:49:23 »
@ Pluto, which model do you have? Your profie shows an SV650.
Don't the newer models V-Strom come out with a fast idle assist feature? I wonder how much influence the fast idle assist has on throttle snatch?
 I recall reading that the throttle snatch was also possibly due to too much slack in throttle cable adjustment and / or the throttle grip itself, https://www.v-strom.co.uk/smf/index.php?topic=40246.0
