TPS again!
Topic: TPS again! (Read 532 times)
Tone
Bike: 2020 V, XT 650. 2022 Triumph speed twin 1200. 1953 BSA A10 plunger.
TPS again!
March 04, 2023, 10:33:01 »
Hi blokes, I’ve read quite a bit about adjusting the TPS sensor, when I put mine in diagnostic mode I get c00 with no dash in front, does this mean I can’t adjust it? 2020 XT. Thanks.
Upt North
Bike: DL650 L7
Re: TPS again!
March 04, 2023, 13:20:07 »
Do you get a dash before the C OO. Like - C OO.
Upt.
Upt North
Bike: DL650 L7
Re: TPS again!
March 04, 2023, 13:21:09 »
Sorry just read you don't get the dash.
Gert
Re: TPS again!
March 05, 2023, 06:45:28 »
Any change in the C00 dispaly once the engine is at idle vs ignition on but motor not running? Perhaps post a pix/
Also have a look at a similar query that was asked in #43 of
https://www.stromtrooper.com/threads/snappy-throttle-on-off.417677/page-3#post-5434775
and a heads up posted in reply #80 of the same link, the bottom sensor is the TPS.
Gert
Re: TPS again!
March 05, 2023, 07:21:51 »
and a heads up posted in reply #80 of the same link, the bottom sensor is the TPS. Finally reply #113 in the linked thread explains the TPS adjustment procedure solution for EURO4 bikes.
Tone
Re: TPS again!
Reply #5 on:
March 05, 2023, 10:04:49 »
Thanks Gert, Good info.
Gert
Re: TPS again!
Reply #6 on:
March 06, 2023, 09:06:16 »
TPS again!
