TPS sensor
Topic: TPS sensor (Read 491 times)
tony d
Bike: DL1000 L5
TPS sensor
February 23, 2023, 18:11:41 »
Hi put bike in dealer mode checked sensor position the line was on the bottom tried to adjust but the line stayed on the bottom
Barbel Mick
Bike: 800RE
Re: TPS sensor
February 23, 2023, 18:42:37 »
It may well be faulty of course, but it is a bit awkward to adjust, the slightest movement can put it out again, including tightening the screw! It took me a few goes to get mine to sit in the middle.
Barbel Mick
Bike: 800RE
Re: TPS sensor
February 23, 2023, 18:49:16 »
There's a few posts about this subject, if you search for TPS adjustment, or similar you should find some like these...................
https://www.v-strom.co.uk/smf/index.php?topic=24218.msg236664#msg236664
https://www.v-strom.co.uk/smf/index.php?topic=41251.msg423480#msg423480
tony d
Bike: DL1000 L5
Re: TPS sensor
February 23, 2023, 19:42:24 »
Thanks
Gert
Re: TPS sensor
February 24, 2023, 06:34:51 »
Make sure that you are making adjustments to the correct sensor. You are looking at the bottom sensor.
The parts list sketch shows that both the TPS and the STPS have the same part number. See the part #2 in
https://www.partzilla.com/catalog/Suzuki/motorcycle/2015/v-strom-1000-dl1000al5/throttle-body-dl1000al5-e03
(Note: the letter S in Suzuki must be in the lower case for the link to work correctly)
tony d
Bike: DL1000 L5
Re: TPS sensor
Reply #5 on:
February 24, 2023, 14:22:04 »
Thanks it was the top one I was trying to adjust
TPS sensor
