Author Topic: Caliper pin plugs.  (Read 543 times)
Offline Upt North
  • Bike: DL650 L7
Caliper pin plugs.
« on: February 22, 2023, 13:38:35 »
Can anyone recommend an hex key replacement for the oem.
I normally use ProBolt but they don't seem to list 2017> 650's. Although they probably do a stainless one to suit.
Ta me ducks,
Upt.
Offline Upt North
  • Bike: DL650 L7
Re: Caliper pin plugs.
« Reply #1 on: February 22, 2023, 13:42:16 »
Also, I spose I might as well change the pads whilst I'm cleaning the rear caliper, are EBC174HH the accepted go to.
TIA,
« Reply #2 on: February 22, 2023, 18:22:43 »
    If you are talking about the plug with the screwdriver slot in it that is a pain in the b*tt to get out,just get a 1/8 BSP plug,the original are 1/8 NPT.The thread is virtually identical to the original and fits spot on,they have an Allan key fitting and are a little longer so stick out a little more than the original.
    Yes EBC 174HH are the pads to use in my opinion.
Offline Upt North
  • Bike: DL650 L7
« Reply #3 on: February 22, 2023, 18:35:52 »
Thanks Ian, hadn't really thought about obtaining non specific fitments, but a quick check online shows generic stainless grubs in metric too.
I'll just need to measure the thread size before ordering......or does someone already know?
I bet you do?
Thanks for the pad info.....
Upt.
« Reply #4 on: February 22, 2023, 18:43:22 »
        UPT…….. As stated the thread size is 1/8th.BSP.(one eighth British Standard Pipe thread) and it’s called a “plug”.
   BTW,it is no good measuring the thread diameter with BSP stuff,it has more to do with the pipe ID than OD.Just take your old one with you when you buy.
   This is a brass one,I prefer steel or stainless as they are tougher.
Offline Upt North
  • Bike: DL650 L7
« Reply #5 on: February 22, 2023, 18:45:53 »
Ta me duck.
« Reply #6 on: February 22, 2023, 19:02:32 »
     Sorry forgot to add that to get a tapered plug ,add a “T” at the end of BSP as in BSPT,that will get you a plug that will start in the threads easier.
      See below for an example.As you will see they are cheap enough so buy a few.Any Plumb Centre should keep them.
