Author Topic: Rear shock not showing full adjustment lines.  (Read 507 times)
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« on: February 15, 2023, 18:46:19 »
I've refitted my rear shock after installing new cushion lever bearings, but my rear sock will now only adjust from position 0 (softest) to position 2, even when turned fully clockwise. All torque settings are correct on shock mountings and cushion lever. Any ideas? Thanks in advance.
Re: Rear shock not showing full adjustment lines.
« Reply #1 on: February 15, 2023, 19:37:56 »
Can't say why it would do that just by removing it & refitting it but have a look at this & see if it helps.................
https://www.v-strom.co.uk/smf/index.php?topic=40447.msg414848#msg414848
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« Reply #2 on: February 15, 2023, 20:10:14 »
Starting with the adjuster fully clockwise, I'm getting 20 full turns anti-clockwise.
The workshop manual states that the shock is nitrogen gas, does anyone know if the adjuster is hydraulic?
I think that I may have found the answer, has anyone done this before?
https://www.stromtrooper.com/threads/bleed-the-rear-shock-preload-adjuster.344537/
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« Reply #3 on: February 16, 2023, 15:42:59 »
Result.  :lala:
Disassembled the adjuster and found a bearing washer in pieces, drained out all the old oil and replaced with 10w fork oil, rebuilt the adjuster and it works perfectly.
« Reply #4 on: February 16, 2023, 17:42:34 »
     Do you mean the thrust washer that looks like a thick flat washer with needle rollers set into it ?if so did you just stick it together with grease and reassemble ?
     I used ordinary engine oil in mine as it takes no part in the damping whatsoever.
Offline Mojo-Jojo
  • Bike: DL1000GT K6
« Reply #5 on: February 16, 2023, 20:04:57 »
No, the thrust washer was in perfect condition it was one of the washers that sit either side of it, it was in 5 or 6 pieces.
« Reply #6 on: February 17, 2023, 10:57:06 »
   Hmm,that's unusual,I don’t think I have heard of it before.
