Suzuki DL1000 V-Strom 2005-2007 Side Stand Extension
Topic: Suzuki DL1000 V-Strom 2005-2007 Side Stand Extension (Read 507 times)
Allan Cross
Bike: DL1000 K5
February 01, 2023, 22:24:05 »
Struggling to find a Suzuki DL1000 V-Strom 2005-2007 Side Stand Extension , however even loads of DL650 ones.
So the question do both bikes have the same deign side stand, so I could use the 650 variant for my 1000?
Thanks in anticipation
Rgds Al
Rixington43
Bike: DL1000GT K7
Re: Suzuki DL1000 V-Strom 2005-2007 Side Stand Extension
February 01, 2023, 22:44:32 »
I have one of these;
https://www.marselus.com/en/d/rozsireni-bocniho-stojanu-Suzuki-v-strom-1000-rv-2002%E2%80%932011-1000015/
They post to the UK and the parts are well made from stainless steel. If you have a centre stand then it won't work as designed and I had to reshape mine. Without a centre stand it should work fine.
Rixington43
Bike: DL1000GT K7
February 01, 2023, 23:10:51 »
There's also this one which I looked at and seems like it might clear both exhaust and centre stand. It looks kind of gnarly but might be worth a punt if the shipping isn't too brutal.
https://advalp.pl/en/side-stand-extension/DL1000-02-13-1side-stand-extension.html?SubmitCurrency=1&id_currency=1
graingerblaze
Bike: DL1050
February 02, 2023, 00:32:06 »
Nice looking stuff, just bought a a side stand extension foot for my bike. Once fitted I will post feedback, hopefully all good as not a bad price (£3.75 postage from Poland).
DL1050 Grey (2020) V-Strom
Allan Cross
Bike: DL1000 K5
February 02, 2023, 01:16:13 »
Thanks blokes something for me to consider for sure
Gert
Reply #5 on:
February 02, 2023, 05:15:31 »
Have you considered going the DIY route? Basically a foot print enlargement plate can either held in place by welding or by drilled then using metal screws / bolts locked in place with a nyloc nut. If you intend welding the plate to the side stand, take time to read the advice in reply #1 of
https://www.vstrom.info/Smf/index.php/topic,6662.0.html
. It could save you some unecessary expense on the ECU and maybe ABS
To me, the link that I posted in my reply #12 of
https://www.v-strom.co.uk/smf/index.php?topic=41878
, explains the process and can be applied to any of the V-Strom models.
Granted, a slight modification may be required, if you have a ceter stand fitted. Often the shape of the side stand foot print will touch a center stand, which may require a small clearance to be file into the new side stand plate.
Rixington43
Bike: DL1000GT K7
Reply #6 on:
February 02, 2023, 09:20:58 »
Out of pure curiosity I've ordered the Advalp one as well since it was a whole £24 posted. I'll report on how well it fits/works once it arrives.
From the blokes website, it appears he rides or at some point did ride a DL1000 himself so he clearly has taste
Ianmc
Bike: DL650AL5
Reply #7 on:
February 02, 2023, 20:57:22 »
I simply cut a piece of aluminium plate to size and to miss the centre stand, and then put it under the stand and drilled 2 small holes through the stand and plate, then bolted them together, job done for just a few pence.
