Author Topic: Another question.....  (Read 1530 times)
Offline Upt North
  • Bike: DL650 L7
Re: Another question.....
« Reply #20 on: February 13, 2023, 00:00:55 »
No welding involved Artyman...not yet anyway.
Hopefully the 6mm aluminium plate will sort the issue, we'll see.
Upt.
« Reply #21 on: February 13, 2023, 06:38:46 »
The bolts will work fine, so welding is not necessary, unless very thin metal plate is used.
Then a tig welder would be a better option than using an arc welder.  It is very easy to burn holes in the thin metal or end up with a bad weld if the wrong arc setting is used.
Just ensure that you use countersink type bolts / metal screws, to keep the underside of the stand as flush with the aluminium as possible. Also use loctite the lock nuts or use else use nyloc nuts to keep things together.
You may want to trim back / grind off any excess bolt thread sticking out above the nuts, to limit any grass etc from attaching itself to the enlarged footprint when riding off pavement.   The lower the lock nut profile the better.
I made use of a PVC cutting board to make a larger kick stand foot print for the XT500.
As a matter of interest, by how much have you increased the foot print?
Does new footprint clear the centrestand when both are in the rest position?
Offline Upt North
  • Bike: DL650 L7
« Reply #22 on: February 13, 2023, 15:58:13 »
Gert and all.
It's on. Not easy to get it to miss everything, but it does.
It's probably doubled the contact patch.
Cost about a fiver all in, but lots of time spent making it as big as possible without touching the stand in two places.
I don't want to file anything for a while.
Upt'North.
Offline Upt North
  • Bike: DL650 L7
« Reply #23 on: February 13, 2023, 16:01:01 »
I thought the 6mm plate may be overkill plus it might hold the bike too high.
6mm turns out to be spot on.
Offline graingerblaze
  • Bike: DL1050
« Reply #24 on: February 15, 2023, 21:15:30 »
Nice solution there Upt North… probably the best route to take! I bought the ADVALP stainless steel foot plate (£25 inc. postage from Poland) and also a cheap aluminium version from AliExpress (£8 but takes 8 weeks).
Both clash with the Suzuki centre stand, but the ADVALP only just. I will cut a little off (marked in photo) then a perfect fit! The aluminium one would need so much butchering it would look awful so will loose that in the toolbox along with all the other failed tries.
DL1050 Grey (2020) V-Strom
Offline Rixington43
  • Bike: DL1000GT K7
« Reply #25 on: February 15, 2023, 21:21:34 »
Good to hear, I'll assume my Advalp one will be along in a bit then and we'll see how it gets on with the double whammy of centre stand and left side exhaust.
  • Bike: DL1050
« Reply #26 on: February 16, 2023, 09:48:35 »
Grinder attacked and now all clear and a perfect fit!  :)
Offline Upt North
  • Bike: DL650 L7
« Reply #27 on: February 16, 2023, 11:15:35 »
Well done fella.
