Hi, my 650X has done 2900 miles and I have an intermittent electrical problem, when I turn the key the gauges do their sweep but the red light in the middle of the clocks starts to flash which indicates a fuel injection problem, basically the fuel pump circuit is not being energised and I believe the problem sits in the ignition switch. Has anyone else experienced this problem?
It is still under warranty but this is major surgery to change the switch and I am not sure if Suzuki UK will do a complete lock set change.
Your views, thoughts, obscene comments most welcome.
