Author Topic: Rear pads. Easy job?  (Read 875 times)
Offline grumps
« on: November 14, 2022, 09:52:10 »
I have changed brake pads on many a bike but I am struggling to see how the rears on my 2020 plate 650 are done.
I have a Haynes manual and can see what to do, but the caliper is right behind the silencer and that looks to be a whole system right up to the header pipes.
That does not make the removal of the silencer or caliper seem easy.
A few tips would be appreciated. Thanks.
Meanwhile, I’ll start on the front pads👍😊
Offline Upt North
  • Bike: DL650 L7
Re: Rear pads. Easy job?
« Reply #1 on: November 14, 2022, 12:02:11 »
Offline Upt North
  • Bike: DL650 L7
« Reply #2 on: November 14, 2022, 12:06:41 »
If not, there's a lovely French Toast recipe.....  :lala:
Online Rusty Nuts
« Reply #3 on: November 14, 2022, 12:17:14 »
A bit wide of the mark with gen 1 / 2 years.
Offline grumps
« Reply #4 on: November 14, 2022, 12:24:52 »
Quote removed
Yes it does thanks. But, the screws and bolts are behind the silencer so I guess it’s time to start fiddling behind that. Silencer won’t move out of the way unless it’s taken off with the whole exhaust system.
I’ll try removing the caliper and raising it above the silencer.
Thanks again.
Online The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
« Reply #5 on: November 14, 2022, 12:32:28 »
Upt North, what a splendid reply. When I read the OP's question I was going to look for a youtube link that could help but what you posted is brilliant, even a monkey could follow.
One bit of advise to the OP, when I changed my pads I replaced the pins with titanium all round. It didn't cost an arm and in my opinion well worth doing. As you can see in the picture in the link, his are rusty and I think you will find your pin are too. Still, most people don't and cleaning the old ones is okay too.  :thumb:
Offline Upt North
  • Bike: DL650 L7
« Reply #6 on: November 14, 2022, 12:36:36 »
Who, who, who, are you calling a monkey  :grin:
« Reply #7 on: November 14, 2022, 12:52:32 »
Or .. if you don't have the tools as suggested,  just remove the back wheel ..
Offline grumps
« Reply #8 on: November 14, 2022, 13:24:42 »
I can get at everything except the 90deg flat bladed screwdriver/socket. I have one but when on a ratchet it’s too long - maybe use a small ring spanner on the blade/hex bit?
I have done a test run on the other fixings and although tight I can get to them.
Who designs this sort of crap? If only the silencer came off.
Will be off soon to the local tool shop.
Thanks for the replies everyone👍👍👍
Offline grumps
« Reply #9 on: November 14, 2022, 13:29:17 »
Front pads went aok but the captive nut behind the mudguard was a fiddle to get back in so I won’t take that off next time.
Gave the callipers a good blast of brake cleaner and a scrub of the pistons with a toothbrush👍
Offline grumps
« Reply #10 on: November 15, 2022, 12:38:07 »
How neat is this? The only thing I can't get at on the caliper is the cap for the pad pin.
Found this set at my local (Aladdin's Cave) tool shop. The bits fit into the ratchet so saving length.
I'm not sure the set would take much abuse but for those hard-to-get-at screws or bolts it might just save the day.
Offline Upt North
  • Bike: DL650 L7
« Reply #11 on: November 15, 2022, 16:28:28 »
Looks a nice bit of kit Grumps. I've had mixed results with USPro, I bought a 1/4 inch socket set for almost nowt which is great and also a small tool chest for everyday stuff. But I bought a pair of cutters which were absolutely shite. Thankfully they also cost about nowt and took up little room in the bin.
I would recommend the 1/4 socket set wholeheartedly.
Good luck.
Upt'North.
Offline Upt North
  • Bike: DL650 L7
« Reply #12 on: November 15, 2022, 16:31:41 »
No JIS bits I see, but nothing new there.
Upt'North.
Offline grumps
« Reply #13 on: November 15, 2022, 16:55:35 »
I only wanted it for the slot head bits and the shallow ratchet, but now you mention the lack of JIS bits ( which I had to Google to find out what that was) I will have to go back and complain😂
Offline Robotstar5
  • Bike: DL650K5
« Reply #14 on: November 16, 2022, 16:35:37 »
I've used various ratchet spanners with screwdriver bits to access tight spaces, you can even grind the back of the bit down if needed.
Offline crofty
  • Bike: DL650, DL250
« Reply #15 on: November 17, 2022, 08:35:05 »
Doctor Vstrom has a good video about this
Offline grumps
« Reply #16 on: November 17, 2022, 09:38:59 »
Thank you Crofty and all other contributors👍
