Author Topic: Changing spark plugs  (Read 674 times)
Offline bonne
  • Bike: DL1050 M0
« on: November 02, 2022, 18:40:54 »
I am about to change spark plugs on my 1050. It is a long time since I have had a petrol car, but back then, I changed them myself.
Neven done it on an MC before, but I guess that the different thing here is that the space is much more crowded. The service manualt says to move the radiator out of the way. Any other hints? I guess I need to sleek top in order to make it fit something like this:
https://www.amazon.se/14mm-Magnetisk-T%C3%A4ndstift-Demontering-Skiftnyckel/dp/B097126CRQ/ref=sr_1_6?crid=2H8XIFJQ11W40&keywords=t%C3%A4ndstifthylsa+14mm+krom&qid=1667414240&qu=eyJxc2MiOiIxLjg4IiwicXNhIjoiMC4wMCIsInFzcCI6IjAuMDAifQ%3D%3D&sprefix=t%C3%A4ndstifthylsa+14mm+krom%2Caps%2C124&sr=8-6
I skipped one spark plug maintenance. Should I expect to apply extra force to get the existing ones out?
Online porter
Re: Changing spark plugs
« Reply #1 on: November 03, 2022, 08:41:14 »
I don't know about the 1050 but on my 2014 1000 I was never able to remove the front cylinder plug without removing the radiator altogether. I think on the older vstrom's you can just remove the plug without taking the rad off. Of course the tank and side plastic's must come off to the reach the rear cylinder centre spark plug. The side plugs are easy to get to with only the seat needing removed.
A 14mm spark plug socket or a 14mm long nosed socket will do the job.
You should have no trouble removing them, they might feel tight the first turn or two till the carbon comes off the lower threads.
