Heavy bar ends?
Topic: Heavy bar ends? (Read 1085 times)
Cadbal
Bike: DL1000
Heavy bar ends?
October 09, 2022, 09:44:26 »
I'm looking for some advice to buy heavy bar ends, I always get numbness in my throttle hand on longer trips.
I'm picking up a set of grip puppies(?) and thinking between them and really heavy ends that will eliminate most of the vibration.
Any advice is great, thanks
Upt North
Bike: DL650 L7
Re: Heavy bar ends?
October 09, 2022, 10:26:39 »
Just try the grip puppies first.
My 650 is much improved with the puppies on. Although wasn't that bad before.
If you're fitting your puppies yourself I'd use the zip tie method, simples.
Upt'North.
Rixington43
Bike: DL1000GT K7
Re: Heavy bar ends?
October 09, 2022, 10:43:15 »
Grip Puppies are a god send, especially if you have large hands.
Also, unlikely, but check headset bearings as mine went out and caused epic finger tingling due to the tiny vibrations in the bars.
Brockett
Bike: 2022 Moto Guzzi 850 V7 special in blue, 2022 850 V7 Stone in darkest black, 1998 XJ600n in red. 2021 Royal Enfield 500 Classic stealth.
Re: Heavy bar ends?
October 09, 2022, 11:32:12 »
What model / age
Has it always done this
Check for a loose fixing:- engine, crash bars etc.
Upt North
Bike: DL650 L7
Re: Heavy bar ends?
October 09, 2022, 12:49:07 »
It might be worth checking the bar ends are fitted right too, mine weren't.
Bits missing and half hanging out.
Upt'North.
Cadbal
Bike: DL1000
Re: Heavy bar ends?
Reply #5 on:
October 09, 2022, 13:38:09 »
I used to get it massively on my old sv650, less so on a gs500, its an 18 plate, everything seems to be in great condition in all fairness and its only on longer rides.
pichulec
Bike: KTM 1290 SAS
Re: Heavy bar ends?
Reply #6 on:
October 09, 2022, 15:59:00 »
I am using those. Combined with grip puppies they reduce vibe massively.
Over 500g each
https://www.ebay.co.uk/itm/262590846097
Landsurfer74
Bike: Suzuki V-Strom, MZ TS 125/150 x 2.
Re: Heavy bar ends?
Reply #7 on:
October 09, 2022, 21:35:36 »
I’ve got weighted bar ends ... and no vibes ..... and Oxford heated grips .... and no vibes .....
Per Ardua Ad Astra.
"There are only three sports: Cycle Time Trials, Motorcycle Racing, and Mountaineering; ... all the rest are merely games."
Yellow Brick Toad
Bike: 2003 V-strom 1000
Re: Heavy bar ends?
Reply #8 on:
October 16, 2022, 22:57:06 »
I bought the weighted R+G protection style ones and went back to standard as they're heavier and didn't give me the bad vibrations
Landsurfer74
Re: Heavy bar ends?
Reply #9 on:
October 17, 2022, 13:17:54 »
Do Grip Puppies work over Oxford heated grips ???
Per Ardua Ad Astra.
pieman53
Bike: DL1000 K6, DL1000A L9
Re: Heavy bar ends?
Reply #10 on:
October 17, 2022, 18:53:48 »
Landsurfer74
yep, they sure do have used them for years.
TLPower
Bike: ThunderBastard (KTM 1190 ADV)
Re: Heavy bar ends?
Reply #11 on:
October 17, 2022, 20:13:22 »
Lead shot and silicon in the bars mainly solved my issues.
Keith60
Bike: Triumph Tiger 900 GT Pro, Honda TRX 500FA ATV
Re: Heavy bar ends?
Reply #12 on:
October 18, 2022, 09:16:47 »
I put Barbusters hand guards on and added the weighted bar ends to them, only because I liked the look of them to finish the install. 🤣🤣. I have noticed no difference what so ever to any vibrations. Grip puppies I am a fan of having had them on 4 different bikes. Takes a little longer for the heat with heated grips to permeate through. But great.
Never too old to ride!
graingerblaze
Bike: DL1050
Re: Heavy bar ends?
Reply #13 on:
October 19, 2022, 20:50:23 »
These are excellent heavy bar ends if grip puppies are not enough 😊.
https://www.oberon-performance.co.uk/universal-bar-end-weights/universal-bar-end-weight-large
DL1050 Grey (2020) V-Strom
Heavy bar ends?
