Author Topic: C32 fault code  (Read 421 times)
Offline Greenman
  • Bike: DL650 L8
C32 fault code
« on: September 21, 2022, 22:03:59 »
Hi all,
I wonder if anyone has had the C32 fault code appear and, if so, what did you do to make it disappear ? Bike seems to be running OK, I haven’t had it too long so a little unsure.
Happy to try to work on the bike myself but have no idea where to start !
All thoughts, advice or hints gratefully received :)
Donal
Re: C32 fault code
« Reply #1 on: September 22, 2022, 06:32:10 »
C32 Injector Signal 1, front .
After some research,  it appears this is an interrupted signal from the ignition pickup to injector 1 .
This could possibly be a dirty / corroded connection to the front injector or maybe water has somehow got in there.
Is the fault always there or is it intermittent..?
