Author Topic: WARRANTY - Anodised Finish - Stone Chips On Back Wheel  (Read 872 times)
Offline BlackRockFox
  • Bike: DL650A XT M0
« on: September 07, 2022, 07:58:11 »
I have had a DL650XT for about 21 months. I recently noticed "marks" on the back wheel that would not clean off.
I took it to my dealer and was told that it was stone chips. They tried to get it sorted under warranty but Suzuki have refused.
The chips are mostly on the chain side of the back wheel, so it looks like the chain is picking up stuff and then it is flung onto the back wheel.
I have told the dealer that I am not happy about this as the finish is not fit for purpose. It must be too soft if it is damaged that easily.
I can accept the occasional chip, but this is happening every time I ride and there are quite a lot of these chips. (No chip jokes please)
In 50 years of biking I have never had this problem before.
The dealer has advised me to try customer services first and then go back to them, if no luck.
Has anyone else had this problem as Suzuki (and other manufacturers) seem to be selling more and more bikes with these anodised wheels?
Thanks
Online Upt North
  • Bike: DL650 L7
Re: WARRANTY - Anodised Finish - Stone Chips On Back Wheel
« Reply #1 on: September 07, 2022, 08:36:15 »
Stone Chips?
Are you sure that's what they are. Seems an odd place to pick up stonechips. I haven't got spoked wheels so I can't check mine but I'm sure others will.
Could it be damage caused by solvent fling from the chain lube? The solvent then eating into the anodised finish.
If it is Indeed stone chips then I don't think any manufacturer would replace under warranty.
Upt'North.
« Reply #2 on: September 07, 2022, 08:45:40 »
Thanks for the quick reply, may be useful
No, I am not sure that it is stone chips, it is difficult to see even close up.
It could possibly be solvent but not sure what as I only use vaseline and grease and WD40 on the chain.
Maybe a solvent used to clean the chain at the dealers when serviced.
Offline Whiterose
  • Bike: DL650 K6
« Reply #3 on: September 07, 2022, 09:00:21 »
If the damge is on the surface, try something like Autosol to remove the marks
Offline Steve T
  • Bike: F8GS, NC750X
« Reply #4 on: September 07, 2022, 09:45:55 »
Or you could just get a suitably coloured permanent marker pen  :whistle:
Just saying
Online Upt North
  • Bike: DL650 L7
« Reply #5 on: September 07, 2022, 09:58:19 »
I'd be very careful using anything too aggressive to try and clean the surface. Start on one area with something like WD40 and a fairly non aggressive cloth. If that doesn't work try car wax or T-Cut, but again be careful, I don't know how thick that anodise will be. It should be just fine, but baby steps would be good.
If one product doesn't work just try another gentle offering, so if WD40 does nowt try all surface furniture polish etc.
Upt'North.
« Reply #6 on: September 07, 2022, 11:16:26 »
If you are going to pursue a claim then don't do anything that might further damage the surface. I would not apply any polish as polish removes the surface layer.
Offline TLPower
« Reply #7 on: September 07, 2022, 11:28:44 »
I too really doubt they are stone chips, my spoked rear wheel has never suffered such a fate even after I painted over the original anodizing. Could it be a flaw in the anodizing?
« Reply #8 on: September 07, 2022, 11:39:57 »
I'm fairly certain Suzuki Customer Services will send you back to the dealer...
« Reply #9 on: September 07, 2022, 11:41:18 »
I had this on my first ever DL1000, it was spots of what looked like corrosion under the finish, causing it to bubble.
The wheel was replaced under warranty.
« Reply #10 on: September 07, 2022, 13:02:08 »
3
« Reply #11 on: September 07, 2022, 13:02:51 »
2
« Reply #12 on: September 07, 2022, 13:03:14 »
« Reply #13 on: September 07, 2022, 13:07:04 »
The dealer has advised me not to try cleaning with anything other than soapy water or WD40/G85 which I have done, all to no avail. Thanks for the replies, it is helping, even the marker suggestion  :grin:
« Reply #14 on: September 07, 2022, 13:17:13 »
They do look like chips. The problem I had on the rear wheel of my 2006 DL1000 was larger bubbles/scabs in the finish.
« Reply #15 on: September 07, 2022, 15:08:41 »
Nail varnish is another option. Cyclists use that on frames etc
Online Upt North
  • Bike: DL650 L7
« Reply #16 on: September 07, 2022, 17:26:41 »
Strange little marks aren't they. Still not sure they're stone chips.
How would stones get thrown onto the rim.
Maybe bits of grit thrown off the front wheel onto the chain and then in turn those flung against the rear wheel. Could the rear wheel throw them against the swingarm and then these could rebound onto the wheel.
Still don't see it. But I don't think they look like they'll polish out anyway.
But if the surface is that delicate it shouldn't be on a wheel.
Upt'North.
« Reply #17 on: September 07, 2022, 19:37:50 »
Just found this on an Africa Twin forum.
Looks very similar.
