Author Topic: speedo drive  (Read 612 times)
Offline Yozzer
  • Bike: dl 650 2012
speedo drive
« on: August 08, 2022, 10:14:14 »
hi all I have changed the sprocket size now speedo not at right speed has any one put a drive on the wheel from a older dl as mine is a 2012 one so on sprocket, thanks don't know if can be done, I know the 2011 0ne with abs has still got on wheel thanks wayne
Re: speedo drive
« Reply #1 on: August 08, 2022, 21:00:44 »
None will work...
Your best solution is to fit a speedo healer (healtec) or re-fit standard sprockets.
Online Gert
Re: speedo drive
« Reply #2 on: August 09, 2022, 07:38:43 »
What is the new size of the front sprocket?
I have read on the Stromtrooper site that changing from 15 tooth to a 16 tooth on the L2 - L6 should make the speedo speed more accurate but the trip meter mileage will be off.
See reply #12 in https://www.stromtrooper.com/threads/speedometer-calibration-2012-dl650a.82458/
However if you go to a 14 took front sprocket a speedo healer is the way to go.
Re: speedo drive
« Reply #3 on: August 09, 2022, 08:16:35 »
front wheels from earlier models won't work, you'd have to change the forks too, but the wiring won't fit anyway.
that's if there isn't a difference with the signal sent to the clocks - so unlikely to work anyway.
healtech speedo healer.  :thumb:
I have one on the Varadero as I change the gearing on occasion - great bit of kit and simple to fit.
Offline Yozzer
  • Bike: dl 650 2012
Re: speedo drive
« Reply #4 on: August 09, 2022, 10:18:10 »
I have droped down to a 14 so will have a look at a  speedo healer
