Booster plug??
Topic: Booster plug?? (Read 857 times)
Big mike
Bike: KLV1000
Booster plug??
July 17, 2022, 00:56:17 »
Hi blokes anyone use or have used a booster plug on a old DL1000 or klv1000?? Thanks
Gert
Re: Booster plug??
July 17, 2022, 07:27:47 »
Going by the info on
https://www.boosterplug.com/shop/boosterplug-Suzuki-dl-480p.html
and
, there is a booster plug that has the correct connector configuration pigtails for the KLV / Vee. The first link contains downloadable bike specific installation instructions.
Not sure how accurate the following is, but an extract taken from another website: "To understand how Booster Plug works you have to understand that FI systems have two operational modes: Open-loop and Closed-loop. The booster plug (and most other piggyback tuners) only work when the ECM is in open loop mode. The ECM goes into open loop any time the throttle isn't at a constant position. The second you move the throttle, it goes into open loop and the booster plug has influence over the fueling. This is why this device should have a minimal impact on your fuel mileage. You can trick the ECM into staying in open loop by installing an oxygen sensor bypass, which is basically a resistor instead of an actual sensor to tell the ECM there's a sensor there but don't expect any feedback from it. Usually this doesn't trigger an FI light on the dash but some models are getting smarter about this."
cb1300rider
Bike: 2005 650 VStrom, ST1100, honda c90
Re: Booster plug??
July 17, 2022, 07:39:49 »
My other half had a booster plug on her f700gs, made a huge improvement to the on/off feel of the throttle. We thought it was worth the money.
Hessy
Bike: DL1000 K6
Re: Booster plug??
July 31, 2022, 10:53:29 »
Hi Mike,
yes just fitted one to my 2006 DL1000 .
very easy to fit and makes the bike run noticably better.
Big mike
Bike: KLV1000
Re: Booster plug??
August 08, 2022, 10:39:43 »
My bike seem loads better I'm really happy with the boosterplug
Booster plug??
