www.v-strom.co.uk/shop
Red Oil Pressure Water Temp Gauge Flashing
Topic: Red Oil Pressure Water Temp Gauge Flashing (Read 804 times)
Allan Cross
Bike: DL1000 K5
July 11, 2022, 20:01:16 »
DL1000 K5 Oil Pressure Water Temp Gauge Red Light Flashing on dash any ideas checked levels of water and oil and all seem fine
Any ideas Troops?
Came on tonight, pulled over and checked everything and then started and the warming light disappeared. I don't recall seeing either Temp or oil icon visible.
Gert
Re: Red Oil Pressure Water Temp Gauge Flashing
July 12, 2022, 07:43:21 »
If the cooling fluid and oil levels are good, then it is possible that it could be the FI warning light / dealer mode code alert to get your attention. The dealer mode code should guide you to a possible component malfunction.
Put your ride into dealer mode and ride it while in dealer mode, to see if any dealer mode code is displayed. See
https://www.v-strom.co.uk/smf/index.php?topic=3791.0
and
https://www.vstrom.info/Smf/index.php/topic,7061.0.html
Note: If you switch off your bike the dealer mode will code will clear. Also make sure that the jumper used for the dealer mode doesn't short to anything else.
Report back if you manage to read a dealer mode code other than C00.
Do you have access to a service manual? Your KLV should be the same as a K4-K5 Vee.
The Doctor 46
The Doctor 46
Bike: DL1000A L4. DL650 L2
July 12, 2022, 08:17:03 »
Gert, you are a clever boy and always so helpful
Allan Cross
Bike: DL1000 K5
July 12, 2022, 08:37:31 »
Thank You Gert will investigate and no I don t have a workshop manual . Not sure what you mean by Your KLV should be the same as a K4-K5 Vee.
kwackboy
July 12, 2022, 11:33:26 »
Its the forums abbreviation for a Suzuki 2004/5 Vstrom 1000 .
Rixington43
Bike: DL1000GT K7
Reply #5 on:
July 12, 2022, 11:51:01 »
I think we've got 'Cross Threaded'.
Your K5 Vee should be the same as the KLV1000 from 2004 (Kawasaki painted it Orange but otherwise it's identical) and there is a service manual for that model in the downloads section;
https://www.v-strom.co.uk/downloads.htm
Maybe the manual will give you some clues.
Allan Cross
Bike: DL1000 K5
Reply #6 on:
July 13, 2022, 12:24:40 »
Thank you for this, as it happened I drove past a Suzuki Garage yesterday and I popped in, they plugged it in and it had 13 faults, so they cleared them and if it happens again we should be able to locate it on this occasion. Thanks for your help.
Gert
Reply #7 on:
July 13, 2022, 18:13:48 »
Sorry about the cross thread. It comes from looking up info on a KLV service manual to find a possible solution to a query on a K5 Vee.
