Author Topic: Missfire under load  (Read 482 times)
Offline Bazzab
  • Bike: DL1000 K4
Missfire under load
« on: June 30, 2022, 08:19:24 »
Apologies if this has been covered before but newly here.
Bike is a DL1000 2004 with about 27000 on the clock.
Has developed an annoying misfire when taking off and without giving it much throttle. Also chugs a bit if changing up into second a bit early. If I give it the berries when leaving the lights it's OK but not good when the plod are sitting next to me. Goes fine on the motorway.
Re: Missfire under load
« Reply #1 on: July 01, 2022, 07:33:01 »
Make sure that the hot idle speed is set to around 1200 -1300 rpm. Have you tried readjusting the TPS to see whether the flat spot / misfire in the fueling moves to a different rpm?  Have a look through https://www.vstrom.info/Smf/index.php/topic,6753.0.html
