Author Topic: Squeeling front brake  (Read 1308 times)
Offline The Doctor 46
  • The Doctor 46
  • Bike: DL1000A L4. DL650 L2
Re: Squeeling front brake
« Reply #20 on: June 29, 2022, 17:13:17 »
I fitted titanium pins and new pads. The brakes didn't squeal before and didn't squeal after. I did use copper slip on the back of the pads similar to what Ianmc mentioned as I always have and thought everybody did. I know when the garage changed the discs and pads on my last car they used copper slip too. Anyway, no sqeal. I'll bet your breaks won't squeal either. Good luck.  :thumb:
Offline Jack Meoff
  • Bike: 2015 Dl1000 Adventure
« Reply #21 on: June 29, 2022, 18:07:09 »
Just came back from a quick test ride after fitting everything, didn't use any copper grease except the tiniest bit on the thread of the pins. So far so good. No squealing,  just lever a little spongey and slight binding which I expect to disappear when everything has bedded in. Will post another update when I've added some miles but it's looking positive so far.
Offline endintears
  • Bike: KTM 1190 Adventure
« Reply #22 on: June 29, 2022, 19:24:03 »
My understanding is the grease on the back of the pads thing as a way of reducing noise comes from the practice of putting a layer of grease between the underside of the clip on type of shim and the back of the pad to act as a damper.
I know for sure that not many years ago some OE car pads [VAG] were manufactured that way for that very reason.
This vid explains what I mean.
Offline Jack Meoff
« Reply #23 on: June 29, 2022, 20:01:50 »
As mentioned before, some people swear by it, others swear at it. Both arguments have their merits I guess. I've done it that way for years but this time I'm going without it.
Offline Jack Meoff
« Reply #24 on: June 30, 2022, 12:53:12 »
Just put 50 miles on the pads. Probably around 90% bedded in now.  No squealing and easy set off the anti lock with 2 fingers. Couldn't be happier.
Last pads were definitely the cause as far as I can tell.
  • The Doctor 46
« Reply #25 on: June 30, 2022, 19:49:10 »
Glad you got it sorted  :thumb:
