Hello blokes
Recently my horn and hazard lights on my ’03 DL1000 stopped working. Pressing the horn button does nothing, and switching the hazard switch gives a swift and faint flicker on the turn signals, then nothing except that the turn signals don’t work with the normal indicator switch as long as the hazard switch is activated. They work fine when it is not.
As I can’t remember when I last used any of them, I don’t know when they stopped working or what might have caused it.
Since both have stopped working, I looked for points in the electrical system where both of them are connected. I tried opening up the button housing on the left handlebar and applied de-oxidizing spray for electrical connectors. Did the same with the connector above the radiator. No luck.
All fuses are good.
Anybody got any ideas where to go from here?
Thanks in advance!
